TAPLFO2 Transistor
Started by swinginguitar, June 06, 2011, 05:50:49 PM
swinginguitar
In the suggested schematic for tap tremolo from Electric Druid, there is a 2n3904 between the LFO output and the LED/Vactrol.
Why?
.Mike
That schematic is an evolution of work I did with the VCLFO. I was working on mashing up the VCLFO and the Tremulus Lune.
I didn't know how much current would be needed for the vactrol and the indicator led combined. The PIC is limited to 20mA output.
That transistor is a result of a discussion I had with an EE friend of mine. I didn't want to run the risk of blowing the PICs, so my friend drew up a simple better-safe-than-sorry current buffer for the LEDs in order to protect the PIC in the event the LEDs pulled more than 20mA of current.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
boogietone
The transistor is needed to provide the current necessary to power the LEDs. They (LEDs) typically need on the order of 10-20mA to light up. The PIC provides a control signal that follows the waveform, tempo, depth, etc. out of pin 5 that the transistor uses to drive the LEDs and thus the actual signal processing. Think of the transistor as a buffer for the control signal.
An oxymoron - clean transistor boost.
swinginguitar
#3
Got it!
I've got  pretty good grasp on the code for that LFO, with the exception of the waveform generator/PWM piece. Is there a resource out there for a good explanation of phase accumulators, sine lookup tables, etc in this context?
I'm new to ASM so I think it would  be helpful if I could find an implementation in C/C++ to look at.
EDIT: add to that the frequency lookup -> how are those values calculated?
Hides-His-Eyes
I find it totally unreadable in ASM too. I can't find anybody using lookup tables in C; I think you'd have to construct an array in C and then rely on your compiler to make a lookup table for you. Risky.
PWM is totally compiler dependent when working in C; some compilers have predefined variables for it and others expect you to just set the registers like you would in ASM.
