I need your expert help with an OD-3
Started by thejoe, June 08, 2011, 07:24:21 PM
thejoe
Hello fellas,
So, I've slowly been modding a new Boss OD-3. I had it pretty good but then I couldn't leave well enough alone and now it's not so great. I've noticed a faint hint of a really bad distortion under the whole signal. Like that awful Line 6 Insane distortion. Low but noticeable. I'm not sure how to fix it. If you all don't mind I'll give you all my play by play:
C28- .033mf
IC- TL071
D6- Silicon
D11- LED
C24- .1mf
C7- .056
R13- 1.5k
After all of this I got nuts. I tried to change R15, and R23 because I was hoping they would give the sputtery effect of being over or under biased. They might not have even been the right resistors.
I then thought circuit bending would be a cool idea. I had a wire from C13 that I was trying to bring back through the IC loop. I moved it all around (before R15, after R25, before or after R13). Nothing did anything I was hoping for. Somewhere throughout these last two bold endeavors I did get the sputtery effect but it was short and then stopped. i also don't remember what did it or if something was just shorting on another component or the case.
This is when I noticed that noise.
After this I did some more work moving with the diodes. I had a swtich hooked up and didn't notice much change between some of them. I then totally removed D6. Then I swapped a silicon for D11 and LED for D6 (which i don't like). I also put a JRC1458D in the IC thinking maybe that was the problem. And thats where it stands right now.
Sorry there was so much here. Any thoughts on where I went wrong?
Joe.
ayayay!
Do you have a schematic or this or are you just doing the "ready, shoot, aim" thing?  I'f you have a schem, please share.   ;D
thejoe
Sorry, here's the schematic.
http://www.freeinfosociety.com/electronics/schemview.php?id=2299
I've modded lots of things before by following other people's ideas on the internet. But I got this pedal for free and just let myself get too wild.
thejoe
I'm going to try and take another crack at this today or tomorrow. I'm thinking it's either one of the electrolytic caps or one of the Jfets. Thoughts?
thejoe
Though I doubt anyone is tracking this thread, I did some prodding today with the audio probe. Everything sounds great until I get up to the collector of Q11. This is also, of course, the beginning of the overdrive circuit. I noticed that the emitter and base give no sound at all but R52 is still producing a dirty signal. Is that weird? Could the transistor be bad?
HOTTUBES
#5
I'm going to assume you have an adaptor for your op amp , cause the factory op amp is an inline unit , where as the JRC is an 8 pin dip !
http://cimarrontechnology.com/ProductImages/smadapters/bd060301_7.jpg
have you tried putting the factory op amp back in ?
HOTTUBES
What kind of sound are you shooting for with this mod ??
thejoe
I don't exactly have that adapter but I made one on vero board. I'm still a bit green with mods. I was trying to make it sound like a more true overdrive. I knew that going asymmetrical on the clipping would help a bit. And I wanted it to sound real rock and roll like. It got to a point where it was a nice chimey overdrive, 70's sounding. I did notice that it wasn't as full on the low end though. So I was trying to add that and also thought I'd give a go at trying to get it sputtery which is where a lot of this went wrong.
HOTTUBES
Try this ....
1. reinstall the stock chip
2. remove C7 & C8 ( no jumper required )
3. C13 - 1 uf
4. C22 - .1 uf
5. C18 - .15 uf
6. C33 - 1 uf
7. C34 - .47 pf
8. D7 - LED and 4148 in series
9. D11 - LED
If the pedal is all stock  , this is a nice improvement !!
thejoe
Ok thanks. I'll give this a shot. Any advice on what the crappy little under tones i was mentioning might be coming from?
HOTTUBES
Ooops !!
Correction :
C34 should read   470 pf
Not .47 pf    !!!!
HOTTUBES
Question ?
If you hit a chord , and as the chord is decaying and fading out , do you hear the strange sounds at this point ??
thejoe
Quote from: HOTTUBES on June 12, 2011, 07:49:44 PM
Question ?
Yes. The pedals main tone is nice but underneath is a really dirty, really fake sounding distortion. I'm noticing it mostly as the chord rings.
HOTTUBES
 :icon_confused:
I have had this problem in the past as well , and it always ended up being in the clipping arrangement , i think it comes from clipping
a single stage to hard etc . To be honest ,i don't know the technical side of this stuff that well , but i have modded this pedal (OD3)
many times with good results , but they have all been in stock trim when i started the mod .
thejoe
Great. Well thanks for all of your help. I'll probably get around to this next week and let you know how it goes.
