Jacks on top
Started by rockhorst, June 09, 2011, 10:02:38 AM
rockhorst
So, to save precious pedal board real estate, I made the following drilling template with input/output/power on the top side of a 125B. I realize that there will be a slightly longer wire to get the signal to and from the switch, for which I plan to use shielded wire. Other than that, does anybody see any problems with such a design?
(If anyone's interested, I can post the diagrams with full measurements, which can be used for instance by Pedal Parts Plus)
Nucleon FX - PCBs at the core of tone
ThunderShowers
Be double sure your jacks are not going to hit your pots.
Did that once already. (Looks like it should clear though...)
  The straight jacks sticking up wasn't what I wanted, angle jacks had a tended to interfere with the controls.
  I put the jacks on the fronts and use angle jacks, have seen others who have thought through all the angles and looked to be doin' well with the top mounted jacks.
EATyourGuitar
this helps a lot but no battery hookup.
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
nocentelli
Quote from: rockhorst on June 09, 2011, 10:02:38 AM(If anyone's interested, I can post the diagrams with full measurements, which can be used for instance by Pedal Parts Plus)
Please, do - I've used this arrangement before, ands the jacks have cleared the pots but more by good luck than good judgement: A 'verified' drill template would be very useful!
Quote from: petemoore on June 09, 2011, 11:28:04 AM...have seen others who have thought through all the angles and looked to be doin' well with the top mounted jacks.
I've found alternating "top jack" and "side jack" pedal works well for saving some sideways space, whilst reducing the number of upwards pointy cable you would get if they were all topjacks.
LucifersTrip
should be cool as long as you use something similar to
always think outside the box
jimmybjj
Quote from: EATyourGuitar on June 09, 2011, 12:40:24 PM
Do you know of a source in the US for these?
EATyourGuitar
rockhorst
Indeed, I don't do batteries. Never did, never will. But if you move the switch a few fractions of an inch upwards, you can easily fit in there. I'll post the diagrams soon. Treat them with caution for now, they're still unconfirmed (awaiting the first batch from PPP).
DonB
GGG sell predrilled 125B enclosures with the jacks on top. Just look in parts list.
rockhorst
Neat! Never noticed (never ordered there). Still, it's neat to have my own ;)
