Channel select circuit needed.
Started by DonB, June 14, 2011, 03:52:49 PM
DonB
Ok i have looked over the web for weeks looking for a cicuit for channel selection.
What i want to do is :
Change channels on my amp and select to either engage a loop or bypass it at the same time.
I use an OD on my gain channel and am sick of tap dancing to go from clean to gain. Having to press the channel select on, od off and fx for clean channel on.
So if i could have a circuit that lets me press to change channel on/off plus od on/off that would help alot. My amp is a blackstar and i think it uses pulse switching. (changes channel when i tap the wires together)
I use my OD in front of the amp, everything else in in the loop. So Its just the OD and gain on to clean no OD i need help with.
Did you try what I suggested in your other thread about this? If that doesn't work have you got a schematic for the amp, might be useful to see how the switching works.
DonB
Was that the one where i connect the 2 outer tabs on the middle row of the 3pdt switch?
If it was it didnt do any good. I thought if i could get a vero or pcb diadram for the channel switching, then i may get what im after.
DonB
So anyone have any ideas on what type of circuit i need to make to achieve channel selection?
