QuantumDrive Distortion?
Started by Paul Marossy, June 16, 2011, 12:31:11 PM
Paul Marossy
From an ebay ad:
"This is Acoustic Imaginearing's flagship pedal that uses a patent pending process to distort the sound by means of quantum mechanical tunneling. By using this process, electrons can tunnel though a barrier at a much more sensitive level than using standard diode distortion. This process also allows the waveform to enter a region of negative resistance, which is unlike any other distortion pedal on the market."
Anyone ever attempt to figure out this pedal? Is this something like a Tube Screamer with tunnel diodes or something?
Only asking out of curiousity is all.  :icon_wink:
Whatever it is, it doesn't really sound all that different (from clips, anyway) than a whole host of other things.  That certainly doesn't mean it isn't a clever way of doing what it does.  But certainly what it does is something I've heard a zillion times before.
Paul Marossy
I think their angle is that it's supposed to be super "touch sensitive" or something like that...
Gordo
Is Mike Mathews involved in this venture?  Also, is it just me or does anyone else smell burning rope?  8)
Bust the busters
Screw the feeders
Make the healers feel the way I feel...
Quote from: Paul Marossy on June 16, 2011, 01:19:19 PM
Aren't they all?
If a person wants "touch sensitive", just take out the damn tube rectifier and stick diodes in place of it, turn down the gain, and crank the master volume.
iccaros
I would worry about quantum entanglements, then you could create distortion in someone else pedal. ...
Paul Marossy
Quote from: iccaros on June 16, 2011, 05:48:40 PM
Ha! That's good.  :icon_lol:
cpm
Quote from: cpm on June 16, 2011, 05:58:55 PM
http://en.wikipedia.org/wiki/Tunnel_diode
actually, i think i have seen a schematic for a pedal using one oh those, although it was part of the switching/battery check section.
Derringer
Quote from: Paul Marossy on June 16, 2011, 05:49:42 PM
I'm holding out for the Superposition-Drive
it has lots of options
Paul Marossy
Quote from: Taylor on June 16, 2011, 06:05:56 PM
http://www.diystompboxes.com/smfforum/index.php?topic=85989.0
That thread looks like it's pretty much talking about what Acoustic Imaginearing says about its pedal. I wonder if they got the idea from this forum?
Taylor
No, that thing existed when I posted that originally, I linked it in the first post of that thread. I wonder if Jasper ever got anywhere with that, it was interesting.
Quackzed
I built the quantum drive distortion, and at the same time- I didn't ...  :icon_eek:
emstin1
insert Schrodinger's cat joke here
Derringer
Quote from: Taylor on June 16, 2011, 11:38:36 PM
that pedal definitely did not exist until someone at this forum observed it
newfish
I'd be unsure of gigging with this pedal.  :icon_rolleyes: <sorry>
Surely the most important part of any OD / Distortion box is not the Op-Amp / Mojo / Manufacturer's Hype / Diodes kintted from Superman's underpant fibres etc, but the filtering?
Sure - the diode itself is clever, but in this application, will it make *that much* difference?
Happiness is a warm etchant bath.
anchovie
iccaros
Quote from: Derringer on June 17, 2011, 06:25:51 AM
:icon_mrgreen:
once you observed it, you can not be sure it still works, as you changed it...
http://en.wikipedia.org/wiki/Uncertainty_principle
thedefog
#19
Quote from: newfish on June 17, 2011, 07:30:57 AM
I was just going to say, unless you're hell bent on edging into microwave frequencies with your stomp box, it is sort of overkill.
Then again, that might be a useful pedal to use on hecklers.
