Re: "Little Angel" - Super Simple PT2399 Mini Chorus
Started by WiLL_GS, June 25, 2011, 10:53:30 AM
WiLL_GS
Hello guys! I'm from Brazil, and it's my first time here. I found this topic and I liked a lot. Than, I decided to make a Little Angel. I've got the components and I build it, but didin't worked. I plugged my guitar, and befote I turn on the Little Angel, the sound's guitar is normal, but when I turn on, I don't hear any noise more. I've verificad, there is no point of short circuit. This is the model that I follow:  http://imageshack.us/photo/my-images/39/111xl.gif/. I think I made a mistake somewhere, but someone but someone has already built this circuit and it worked correctly?? One more doubt, I just find this layout: http://imageshack.us/photo/my-images/4/layout1111.jpg/ . I tried to print several times, but the size was not the same as the circuit, so I did another by following links from this, only then could the actual size for the components. At least that part I know is right because I checked several times. I'd like to know how you get to print the same size as real. If I do not think the problem the way I did, I do it again with the original layout. Later I'll post some pictures of this project, other guitar pedal and also my amp, I did it by myself, all are very simple but work fine. Please help me! See you later, thanks a lot!!!
