what does this schematic symbol mean?
Started by pinkjimiphoton, July 15, 2011, 01:04:48 PM
pinkjimiphoton
i've never seen it before...
is it a pot with two of the lugs tied together?
it's from analogguru's FET booster..
thanks folks!
Slava Ukraini!
~Jack Darr
Trimmer, with lugs 1 and 2 tied to ground.
TP1= Trim Pot 1
Fender3D
It's a trimmer with 2 lugs tied together.
Edit:
Rick you beat me...
pinkjimiphoton
thanks guys!! i learn a lot here, for sure! thanks for the speedy response!  :icon_biggrin:
Slava Ukraini!
~Jack Darr
Gurner
#4
You'll often hear such a beast referred to as a rheostat.....such a config turns a pot or trimmer (which is what the symbol is) from a potential divider into a simple two legged variable resistor.
Ice-9
Quote from: Gurner on July 15, 2011, 02:07:50 PM
I always though a rheostat was a wire wound pot, and rather large component compaired to a trim pot.
www.stanleyfx.co.uk
Gurner
#6
Quote from: Ice-9 on July 15, 2011, 06:20:04 PM
Rheostats are quite often used with higher currents (ie wirewound), but that usage/term is not exclusive.
For example, when buying digital pots you have the option of a standard (three terminal)  pot or a rheostat version (two terminal/variable resistor)... to prove my point, have a look at the top right of this digipot datasheet http://ww1.microchip.com/downloads/en/DeviceDoc/21978c.pdf - these digipots are very low (non wirewound!) current devices ....so the term rheostat has now morphed into a way of differentiating the intended use/config of a pot.....three terminal (potential divider) or two legged rheostat (variable resistor)
Minion
I allways called that pot wiring configuration a variable resistor as opposed to a voltage divider like a volume pot is wired .....
Go to bed with itchy Bum , wake up with stinky finger !!
Gurner
#8
Quote from: Minion on July 15, 2011, 07:57:34 PM
Which is perfectly reasonable ....but the IC manafacturers have now taken a penchant to calling such variable resistors rheostats....I guess it removes any potential for doubt (whilst a volume pot is clearly a potential divider, it achieves this by having a variable resistance on the wiper  ....& let's face it - rheostat is a cool name, we don't often get to use an "h" after an "r" & I was getting sick of singing Rhinestone Cowboy to fulfill this need)
