DUMB newb question re: charge pumps
Started by pinkjimiphoton, July 30, 2011, 01:23:50 PM
pinkjimiphoton
hi guys, need a bipolar 9 volt supply for a pedal i built a while ago, rg suggested using an lt1054cp.
so i made up a vero for it...i know it's probably slightly larger than necessary, but i wanted to have physical room for the components to fit..sometimes a tite layout can be a pain in the...
anyways, would some kind individual be so cool as to look at it for me, and see if i screwed the thing up??
thanks!!!!! hoping to get this in the pedal this afternoon so i can gig with it tonite.
Slava Ukraini!
~Jack Darr
Looks good to me except the 9V - Term and ground rows need connecting together with a jumper or just connect 9volt - term and the bottom of C2 to the ground row and save yourself a row.
I take it Q1 is polarity protection?
pinkjimiphoton
nah, q1 is a switch...when you plug in, it connects to the ring terminal on the input jhttp://www.diystompboxes.com/smfforum/index.php?action=post;topic=92930.0;num_replies=1ack and powers the circuit. its from rg's circuit on geofex for powering it on without having to use a switch.
i kinda worked backwards from this:
http://www.generalguitargadgets.com/projects/24-power-supplies/138-charge-pumps
it looked to me like the ground and circuit ground were separate..oops!  :icon_redface:
thanks!
Slava Ukraini!
~Jack Darr
pinkjimiphoton
yep, i just added a jumper to it across the two bottom rows. when all said and done, really nice toy worked out perfectly.  :icon_mrgreen:
Slava Ukraini!
~Jack Darr
