Debug: no distortion from Dist +
Started by rockhorst, August 04, 2011, 02:53:33 PM
rockhorst
I decided to finish up a Distortion + board that had been lying around for a year. Surprise: it doesn't work the first time I fire it up :icon_mrgreen:. With both pots turned fully clockwise, I get a clean, unity gain signal with a slight loss of high end (could be cable capacitance). No distortion. So if anybody has any suggestions, please share.
The particulars:
Using this board/layout from Newtone, including the asym clipping diode D3.
I used a OPA134 opamp, which has a slightly different pinout than for instance a TL071, with pins 5 and 8 'swapped'. Since these pins are not used in the design, it shouldn't be a problem.
On 9.3V from a wallwart, without a guitar signal, all the diodes register 0V at both ends.
IC values:
IC1 = 9.3 V
IC2 = 4.7 V
IC3 = 4.1 V
IC4 = 0V
IC5 = 0 V
IC6 = 4.6 V
IC7 = 9.3 V
IC8 = 9.2 V
Nucleon FX - PCBs at the core of tone
If it's passing signal but turning the gain pot does nothing then you've probably either got a short between pins 2 and 6 of the opamp or a break somewhere between pin 2 and ground, either of those things would basically make it into a buffer.
Also check the values of R3 and R4 if they were wrong that could give little or no gain.
rockhorst
Gotta love this place. R3 was the culprit.
NOW all that's left to be done is to see if we can actually make it sound GOOD ::)
Quackzed
     ,---si'<---si<----,
----l--->si'--->si----l-----
for overdrive/dist vibe...
     ,---si'<---ge<---,
----l-------->si'------l-----
for heavier asym distortion...
the dist + doesn't get enough credit imho...
its a straight up clipping stage without alot of frills, but thats whats good about it in my book.
