WAH pictures- diy , modded & etc.
Started by joegagan, August 05, 2011, 02:11:40 PM
Gus
fretzburner
Modded this one because i can't find the dual pot 50k/500k,now i need to find 50k long shaft for this.Anybody here can give me link? i need 16mm size 50k long shaft.
image hosting youtube
I preserved the fuzz and the switching but i noticed a delay when i turn it on.split second silence before the wah engage.
joegagan
can you post pictures of the inside? and the original pot? i can make up something custom if needed.
fretzburner
Fixed it already using ordinary 50k pot,still waiting my long shaft order.This is the pcb  picture.
how do you print screen
Used the single pot version into the wah portion of this wf10 and working fine now but will change the pot as my order arrives.
tony grazioso
whew, where to start..ok, true by-pass switching, vocal mod, mid mod, dual inductor mod with a switch to choose between the two. whipple inductor with a bare stock stack 'o dimes inductor. Icar taper pot. hand etched board, gain mod..9/18 volt mod with a switch to choose between the two. dual led's (for you left or right foot wah users...the list goes on and on and on.
joegagan
Güero
Circuit developed with Fabio Zaganin , a great brazilian bass palyer.
Electronic circuit controller bypass (foot in the ramp = ON) adjusted shutdown time + true bypass.
Adjustable input signal for active pickups, Bass Enhancer, Volume, Slime (funk a like), Mid Shape, 6 position Range (treble and bass) and Bite.
Independent output for tuner.
Curing the infection one bullet at a time.
ch1naski
Wow. Just wow. These last couple of wah's are awesome. Great job, guys.
Mockingbird wish me luck.
joegagan
wow, that i s very beautiful, guero. love the bold color scheme, and the execution is gorgeous.
Güero
#310
Quote from: joegagan on September 12, 2013, 01:29:15 AM
long time :D
Thanks Joe !
1878
Whipple Wah in an old Frontline Volume pedal. Sort of thrown together at the moment to see if I like it or needed to mod it, so I'll probably do a proper job at a later date. Standard 100k pot 'cos of the non-Crybaby setup. I really like the 'vocal' mod as it allows me to tone it down a bit when I'm not using a distortion after it
The throw on this thing is massive !! I used it as a volume pedal for years so I was used to the feel of it, but as a Wah it's so much different to a Crybaby type set up.
Sounds lurrrrvley.
MisterBlue
#312
Hi Guys!Here is mine, point to point method Icar superswell Pot and Philips tropical fish capacitors
^ love the colour scheme...nice old vintage look to it.  8)
disabled_shredder
I am posting this photo to this thread in hope someone that has posted on here will see it and be able to help I am looking to find 2 .22 caps like the smaller .01 caps on here. I wan to get rid of the big grey box caps and make it period correct if anyone knows where I can get them please let me know! Thanks
The wild man with a loaded gun and no plan. I'm not held back by rules, just don't know which ones to follow
Liquitone
I have looked at a lot of the earlier Italian wah boards ( to try and put a date on a late '60 early '70 Jen CryBaby I had in the workshop, and it looks like they used anything they had at hand in these,
so I think these are in fact period correct. But I can see why you would want to put .22's similar to the .01's in here.
disabled_shredder
I guess if I can't get the caps I will put a 9v adapter board on build it true bypass ic buffer out w off switch range control and probably change out the elecs but I will save them so I can undo almost all if I choose to sell it down the road.
joegagan
the thomas caps are most likely polyester film and foil. some of the wah guys i respect tell me they really do make a difference in the tone. i haven't done any real testing myself so i can't say. but they sure look cool.
ch1naski
There is a company that puts out "aged" poly caps, they're somewhat similar in shape, axial, and yellow.
paulyy
@disabled_shredder
Here's a link that might help. I didn't see any .22 caps like this but they maybe able to help you if you ask.
http://www.ebay.com/itm/3-ITW-Paktron-015uf-100V-Poly-Film-and-Foil-Capacitors-10-NOS-Guitar-Tone-/370909382441?pt=LH_DefaultDomain_0&hash=item565bec0729
I do have some .22 caps but they are just a little to big to fit but the look identical to the one's in the Thomas organ wah's.
