Creating PDFs
Started by Mike Burgundy, August 09, 2011, 12:47:33 PM
Mike Burgundy
There are some very nicely done PDF files around with all info on a project neatly contained in one package, with the added bonus of printing the pcb layout to correct scale too. I can print pcb designs to pdf (Eagle), but how do I combine them with schematic, parts lists and accompanying text into one document - what does everyone use for this purpose?
theehman
Ron Neely II
fx schematics and repairs
defaced
-Mike
Fender56
I use PDFTK Builder to combine many PDFs into one file:
http://www.angusj.com/pdftkb/
asatbluesboy
...collectors together and emitter to base? You're such a darling...
ton.
Thomeeque
#5
 OpenOffice.org (but I'm exporting pictures from Eagle as hires bitmaps, I don't know how to get it as a vector graphic*) T.
EDIT: IrfanView is able to make multipage PDF from a list of pictures too btw.
EDIT2: I already know (CAM utility => EPS) :) I'll try it next time..
Do you have a technical question? Please don't send private messages, use the FORUM!
I've used Inkscape to edit/create the sheet with multiple images/info.  Then create the pdf printing the image using Bullzip pdf printer. Bullzip also lets you create a multi-paged document. Both freeware.
http://inkscape.org/download/
http://www.bullzip.com/
dave
Mike Burgundy
Thanks, should get me going ;P
Galego
aron
On the Macintosh, preview will do what you need.
Galego
Quote from: aron on August 16, 2011, 05:50:19 AM
Or Print > save as pdf.
