Foot controlled flanger?
Started by nexekho, August 30, 2011, 07:36:38 PM
nexekho
I've been playing around with the POD flanger for a while (using Vyzex which exposes a lot of settings) and I love some of the soaring noises that can be had with it, but find being stuck to a LFO restrictive.  As far as I can tell from the little bit of research I've done, a basic flanger is a mix of your signal and an echo that repeatedly catches up and then lags behind, the motion controlled by the LFO.  Has anyone ever tried controlling the amount of lag using a wah-style foot potentiometer?  It'd be awesome to be able to control the exact sweep of the whoosh.  Is this possible using the standard echo ICs like the PT2399?  As most look like they use a LED+LDR combo to control the sweep, it might just be a case of swapping the LDR for the potentiometer.
I made the transistor angry.
Scruffie
Check out the A/DA Flanger, it has an Expression output for the Manual control which is what you are suggesting... infact any Flanger with a Manual control could be modded to allow expression input.
A PT2399 cannot get in to short enough delays for proper flange, it only just manages chorus.
oskar
nexekho
Quote from: Scruffie on August 30, 2011, 07:50:04 PM
If you ran the dry through its own PT2399 set to minimum delay, you'd get an overall latency but a flange range of zero->limit of PT2399 right?
Thanks for that link, I'll look into it.
oskar
Quote from: nexekho on August 30, 2011, 08:02:04 PM
That could work.
oskar
#5
... But a flanger is using feedback of the delayed signal and the signal fed back would only be within 'flange' delaytime the first time.
The subsequent delays would show up with too long delaytime but it would do something flangy at least.
Edit: I don't know. This got me as confused as timetravel does on sci-fi channel.
oskar
If I understood you right it would look something like this:
I can't make a flanger out of it (unless I had a whole bunch of 2399 and different delaytimes and... ) but it looks like a way to build a chorus out of the pt2399.
From the Little Angel thread: http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg722942#msg722942
Those delaytimes are too much latency to play with. At least for me. A clever idea anyway.
Govmnt_Lacky
Quote from: oskar on August 30, 2011, 07:54:15 PM
No schematic, but I've got a weak spot for anything tycobrahe...
http://www.effectsdatabase.com/model/tycobrahe/pedalflanger
Ooooooooohhhhhhhhhh!!!!!  :o  :o
I like this!
Please tell me that there is a PCB layout floating around for this......  :icon_lol:
You REALLY want to embark on an MN3001-based flanger?
nexekho
Ok, so I had another random idea: I was flicking through the Falstad examples when I saw a LC ladder and noticed it resembled a spring, kinda like a reverb tank and designed a basic reverb around a ladder made of some slightly easier to find parts.  I have no idea what it would sound like or if it would even work, but I couldn't find any inductor reverbs in my searches.  Includes a buffer/preamp, a feedback, and the ability to separate it into dry/wet channels for use with stereo equipment.  Seems to produce some kind of feedback in the simulator, no idea if it's reverb-like or not.  Any thoughts or more amazing articles?  :D  Thanks for that, by the way, it's a great read.
Larger: http://i.imgur.com/Xeolw.png
$ 1 5.0E-6 4.43302224444953 50 5.0 50
l 496 576 544 576 0 9.999999999999999E-5 21.798891477963597
c 496 576 496 624 0 4.7E-4 -2.5440437393267876
w 496 624 544 624 0
w 544 624 592 624 0
c 544 576 544 624 0 4.7E-4 -12.602624851071
l 544 576 592 576 0 9.999999999999999E-5 -15.150146482967688
l 640 576 688 576 0 9.999999999999999E-5 27.89029978165453
c 640 576 640 624 0 4.7E-4 23.7563786019251
w 640 624 688 624 0
w 592 624 640 624 0
c 592 576 592 624 0 4.7E-4 6.949080802070934
l 592 576 640 576 0 9.999999999999999E-5 0.3796321460664314
l 784 576 832 576 0 9.999999999999999E-5 0.9573179212347243
c 784 576 784 624 0 4.7E-4 0.00554607354895121
w 784 624 832 624 0
w 832 624 880 624 0
c 832 576 832 624 0 4.7E-4 18.050761909840002
l 832 576 880 576 0 9.999999999999999E-5 20.152196980800053
l 736 576 784 576 0 9.999999999999999E-5 -3.364204098669264
c 736 576 736 624 0 4.7E-4 -9.978527452162268
w 736 624 784 624 0
w 688 624 736 624 0
c 688 576 688 624 0 4.7E-4 14.361962524375178
l 688 576 736 576 0 9.999999999999999E-5 32.63393705814868
l 976 576 1024 576 0 9.999999999999999E-5 -20.594451798809814
c 976 576 976 624 0 4.7E-4 8.816624727671188
w 976 624 1024 624 0
w 1024 624 1072 624 0
c 1024 576 1024 624 0 4.7E-4 32.02421476887944
l 1024 576 1072 576 0 9.999999999999999E-5 0.20610672381347017
l 928 576 976 576 0 9.999999999999999E-5 -4.267832478502135
c 928 576 928 624 0 4.7E-4 -2.0092714853468734
w 928 624 976 624 0
w 880 624 928 624 0
c 880 576 880 624 0 4.7E-4 13.960529364692254
l 880 576 928 576 0 9.999999999999999E-5 31.20401585759082
174 1072 576 1136 544 0 1000.0 0.48020000000000007 Wave Reflection
w 1072 624 1152 624 0
w 1152 624 1152 544 0
w 1152 544 1104 544 0
g 1072 624 1072 656 0
s 1072 544 1072 480 0 0 false
s 1024 544 1024 480 0 1 false
s 976 544 976 480 0 1 false
s 928 544 928 480 0 1 false
s 880 544 880 480 0 1 false
s 832 544 832 480 0 1 false
s 784 544 784 480 0 1 false
s 736 544 736 480 0 1 false
s 688 544 688 480 0 1 false
s 640 544 640 480 0 1 false
s 592 544 592 480 0 1 false
s 544 544 544 480 0 1 false
w 1072 544 1072 576 0
w 1024 576 1024 544 0
w 976 576 976 544 0
w 928 576 928 544 0
w 880 576 880 544 0
w 832 576 832 544 0
w 784 576 784 544 0
w 736 576 736 544 0
w 688 576 688 544 0
w 640 576 640 544 0
w 592 576 592 544 0
w 544 576 544 544 0
w 512 528 1248 528 0
w 512 496 1248 496 0
x 1077 518 1208 522 0 14 12-pole rotary switch
w 1072 480 1024 480 0
w 1024 480 976 480 0
w 976 480 928 480 0
w 928 480 880 480 0
w 880 480 832 480 0
w 832 480 784 480 0
w 784 480 736 480 0
w 736 480 688 480 0
w 688 480 640 480 0
w 640 480 592 480 0
w 592 480 544 480 0
a 432 320 528 320 1 5.3 -5.3 1000000.0
a 432 208 528 208 1 5.3 -5.3 1000000.0
w 432 336 432 384 0
w 416 304 432 304 0
w 336 384 336 256 0
r 336 256 432 256 0 150.0
w 432 256 432 224 0
w 432 192 416 192 0
w 416 192 416 304 0
w 496 624 336 624 0
R 144 320 96 320 0 1 440.0 1.0 0.0 0.0 0.5
174 432 384 496 416 0 1000.0 0.9851000000000001 Feedback
w 528 416 464 416 0
w 528 416 528 320 0
w 416 480 416 304 0
r 416 480 544 480 0 220.0
r 416 480 336 480 0 10.0
w 336 480 336 384 0
w 336 480 336 624 0
r 336 384 432 384 0 150.0
174 432 256 496 288 0 1000.0 0.9950000000000001 Reverb
w 464 288 528 288 0
a 640 336 752 336 0 5.3 -5.3 1000000.0
r 640 288 752 288 0 1000.0
w 752 336 752 288 0
w 640 288 640 320 0
g 640 352 640 384 0
r 640 320 576 320 0 1000.0
w 576 320 528 320 0
a 144 336 256 336 1 5.3 -5.3 1000000.0
w 256 384 256 336 0
w 144 352 144 384 0
w 144 416 144 480 0
r 144 480 336 480 0 330.0
174 256 384 160 416 0 1000.0 0.9950000000000001 Preamp
w 144 416 144 384 0
w 144 416 208 416 0
w 256 336 256 160 0
w 256 160 544 160 0
w 752 336 752 448 0
w 752 448 448 448 0
w 448 448 448 576 0
w 448 576 496 576 0
r 544 160 544 288 0 1000.0
w 544 288 640 288 0
a 640 224 752 224 0 5.3 -5.3 1000000.0
r 640 208 576 208 0 1000.0
w 576 208 576 160 0
w 576 160 544 160 0
r 640 176 752 176 0 130.0
w 752 176 752 224 0
w 640 208 640 176 0
g 640 240 640 272 0
w 528 208 528 256 0
w 528 288 528 256 0
w 640 224 640 208 0
O 864 160 864 112 0
w 752 224 864 224 0
w 864 224 864 160 0
O 928 160 928 112 0
x 937 141 1089 145 0 14 Optional reverb channel
x 814 139 857 143 0 14 Output
S 528 256 608 256 0 0 false 0
r 640 224 608 240 0 1000.0
w 608 256 608 272 0
w 608 256 656 256 0
w 656 256 672 272 0
w 672 272 704 256 0
w 704 256 928 256 0
w 928 256 928 160 0
x 414 139 524 143 0 14 Reverb amplifiers
x 638 139 760 143 0 14 Summing amplifiers
x 126 299 250 303 0 14 Input buffer/preamp
x 718 651 866 655 0 14 LC ladder reverb "tank"
o 135 8 0 34 4.676805239458889 9.765625E-55 0 -1
o 138 64 0 34 7.62939453125E-5 9.765625E-5 1 -1
Govmnt_Lacky
#11
Quote from: Mark Hammer on August 31, 2011, 09:30:29 AM
Sure! Why not. But, it does not HAVE TO BE 3001 based....
There may be the capability to retrofit for a 3007, 3207, SAD1024, or even 2x 3002s.
All of these are available. Some more than others but, the true question would be whether or not it is worth the undertaking  ???
EDIT: Sorry... I'm a modulation junky  8)
Fair enough.  Then take a look at the Anderton offerings.
Govmnt_Lacky
Quote from: Mark Hammer on August 31, 2011, 10:03:17 AM
I already checked those out Mark. Unfortunately, I am TERRIBLE at doing layouts from schematics  :icon_redface:
Yes, I know I should focus and practice this more. I have been working on simplified circuits BUT, my obsession for modulation circuits needs to be fed.... ya' know?  ;D
Puguglybonehead
A foot controlled flanger! Definitely on my to-do list. (after a few more beginner pedals) You should have a look at the Ultra FLanger by John Hollis.
http://www.geofex.com/pcb_layouts/layouts/ultrafln.pdf
Samples I've heard sound good. It has a manual sweep option which should adapt to pedal use. I've read about problems with the LFO, but I was going to build mine without one, myself. Just foot control! Mutron made a pedal-operated flanger way back-in-the-day that sounded really nice. Never saw a schematic for it, though.
noelgrassy
The best example I ever heard a production pedal perform was the Pluto Pedal made in the San Francisco-Bay Area in
the mid-seventies. It's treadle controlled the Flanging/Phasing effect as well as panning from side-to-side if you ran more
than one amp in those days. My friend in Seattle got weird looks when other bands saw him setting up two Bandmasters
& the hospital White Pluto Pedal. But those same guys $hit a Kosher Dill when plugged in his triple neck built by a former
Alembic luthier, Brian. That axe had three Arp Avitar P-to-V converters in it too. My compadre over-compensated for a
deemed lack of attention sometimes. But his sound was other worldly compared to anything other guitarists were doing!
He literally existed on a diet of Grapefruit to save all the coin his rig eventually cost him. Suffering for his art was his
chosen path. As was performing the spaciest music this side of Sun Ra &.Gong I'd be willing to trade my Left Nut to
get my mitts on a functioning Pluto Pedal now a days! I've never seen one come up on E-bay in twelve years of looking.
Joe Gore a writer for Guitar Player magazine who also gigs with local heavies confided to me he had one he wasn't
willing to part with at any price. He contributes to FSBoxes so I'll hope and pray he traces the circuit out one day and
shares his findings. You TZF cats will dig it I'm fairly certain. :-*
Noel Grassy.
"Of the demonstrably wise there are but two: those who commit suicide, and those who keep their reasoning faculties atrophied by drink." Mark TwGL
Puguglybonehead
#16
OK, I've been thinking about this some more. I was looking at the schematic for the Ultra Flanger on Geofex. Would simply leaving out the LFO section and using the Manual pot (R 23) in a wah-style pedal actually work? Is it really that simple or does the value of the pot need to be changed in order to get the full sweep? I'm guessing that I'm missing something.. :icon_confused:
sewage666
Morley made one...
My guitarist had one of these. It sounded great on auto or foot control. Unfortunately, no schematic available on their website. Probably quite a difficult build with optical sensors.
I have the Morley PFA Phaser. It's the best sounding phaser I have, not to mention the prettiest in bright chrome. Playing with the foot control option is gosh darn fun.
wavley
Quote from: sewage666 on September 12, 2011, 04:21:42 PM
Morley made one...
A big +1 on that good buddy, here's a pic of mine.
edit: by the way, it's the most awesome flanger I've ever played
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
oldschoolanalog
I have a PFL in my stash also. Good pedal. However...
This A/DA "PFL workalike(better)" smokes it. No comparison. The Morley doesn't even come close to this sound wise.
Of course you have to DIY it... :D Not a difficult build. Just a bit fussy-picky getting the LDR's set up "just right".
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
