Fat Pants layout?
Started by carboncomp, August 31, 2011, 07:19:35 PM
carboncomp
What is going on at the bottom of the single sided PCB for the Fat Pants......there is a LED with SW denoted.....is it a switch, a led, and why?  :icon_confused:
nexekho
Take a look in the top left corner of the schematic.  That looks like the offending article.
...no, I'm not entirely sure what that'd achieve either beside a LED you can turn on and off for some reason?
I made the transistor angry.
carboncomp
OK that confused me even more looking at that schematic......why would there be a LED that you can just turn on and off???
So assume I can just omit the LED and R5 resister?
CynicalMan
It's the status LED. You use one of the poles of the 3PDT switch to switch it if you're using one. The LED would normally be mounted to the top of your box and connected to the board with wires.
tiges_ tendres
It's a way to reduce offboard wiring.  The LED resistor is on the board, so you would only need to run 1 wire to the switch to indicate when the pedal is off or on.
Try a little tenderness.
bean
Quote from: tiges_ tendres on September 01, 2011, 01:37:51 PM
Pretty much this.
