Are there schematic examples of Transistor based Spring Reverb?
Started by kimelopidaer, September 13, 2011, 12:56:03 AM
kimelopidaer
I am assuming that this is possible. But if not, would someone explain whysuch?
The transducer and driver circuits both.
I'd also like to see a schem for a little transistor based practice amp -  you know, the ones that
mostly contain the lm386.
thankYou
K
This is a little bigger, but the spring reverb circuitry is shown here:
http://www.univox.org/pics/schematics/u65rn.jpg
Just excise the spring reverb circuitry on the middle right of the schematic and transplant it into your LM386 amp.  The jack at the right is for a switch that grounds the reverb output.  To its left is one of the simplest tremolos i have seen, which also has a jack for a grounding switch.
