Equinox: Easy PT2399 Reverb
Started by merlinb, September 20, 2011, 10:58:27 AM
animal
Good news !!!
I solved the problem, for some reason one of the filter capacitors to ground at pin 7 of the section of the "long delay" was bad, i changed it and now sounds perfect. i don't know if was a bad luck ... but that small capacitor was the problem .....kill me please  :'(
Quote from: dschwartz on November 07, 2015, 01:48:18 PM
Looks like the diode is disconnected from the circuit, i see an unsoldered pin on the bottom right ..
Man that soldering job is NASTY.. I think you should do it again, and get 1mm or thinner drill bits
This diode is disconnected because i made a bridge on the JFET for the effect is always active
and yeah ... i know that soldering it's sucks, but that's because i resoldering many times looking for the problem ... it's kind of pcb test so doesn't bother me it all ejejeej
may also be that the picture not favor much jejej
A lo chilensis: Si en la foto se ve entero penca pero es una prueba asi que no me intereso mucho que se viera bien sino que cumplieran con el objetivo
Saludos !!
Cheers guys !!
thomasha
Good to know that it worked!
when I checked every pin with an audio probe there were some nasty noises.
dschwartz
@Animal
It is not about the looks..huge blobs of solder ussually are more trouble than an effective connection.. Probably the bad capacitor was due to overheating..always use a probe before resoldering to find exacly where the issue is, or thereabouts, then you reflow or check for broken connections or bad components..but adding blobs of soder ussually hide this imperfections..
Tubes are overrated!!
http://www.simplifieramp.com
Windingmachine
I´ve just finished up mine!!
Sounds just like the others i heard from here!
cort viva gold >> noisy cricket amp (1/2 watt) >> handmade 1x12 cabinet with a v30 clone >> SM 57 >> Focusrite Scarlet 18i20 >> Sonar x3 (no filters, equalization or any kind of post production)
https://youtu.be/Q5vkB49cz-Q
https://youtu.be/K2i_sCdw0WY
Hope you like it.
