Socket electronic components?
Started by funkymonk95, September 20, 2011, 04:34:58 PM
funkymonk95
Hey everyone,
I keep encountering stuff like 'you should socket your transistors' or 'socket capacitors'.
Can anyone explain how to socket those components, especially transistors?
Thanks in advance!
arawn
yeah everybody sells "sockets" generally for dip8 or more ic's, sometimes specific ones for tranny's you want the pin type if you get dip sockets just cut'em up with diagonal cutters.
"Consistency is the Hobgoblin of Small Minds!"
Gus Smalley clean boost, Whisker biscuit, Professor Tweed, Ruby w/bassman Mods, Dan Armstrong Orange Squeezer, Zvex SHO, ROG Mayqueen, Fetzer Valve, ROG UNO, LPB1, Blue Magic
CynicalMan
#2
SIP socket cut to your desired length.
http://www.smallbearelec.com/Detail.bok?no=101
Gus
Sockets are not a good idea for effects if they are used on the road.  The parts can/will fall out.
ubersam
Quote from: Gus on September 20, 2011, 06:44:13 PM
yup, happened to a friend's modded ts9. worst part was that it happened during the show (good thing he had a back-up od). as a quick fix we hot-glued the ic in place and planned on soldering it direct to the board when we got back home. but i don't think we ever did.
LucifersTrip
#5
Quote from: funkymonk95 on September 20, 2011, 04:34:58 PM
Hey everyone,
Thanks in advance!
here you can see a variety of sockets for transistors:
http://www.google.com/search?hl=en&q=transistor+socket&gs_sm=e&gs_upl=1663l5270l0l5443l17l15l0l6l6l0l199l1612l1.10l11l0&bav=on.2,or.r_gc.r_pw.&biw=1280&bih=666&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi
I don't socket much, but when I do, I use this type:
You simply solder the socket to the board and then you can plug & unplug all the transistors you want...
always think outside the box
nexekho
I used a pair of ordinary pin headers to socket my Arduino Nano:
I guess you could use them with resistors/LEDs/capacitors/etc.
But socketing other components?  My usual supplier has transistor sockets, don't know how good they are.
And standard DIP sockets.  They're nice and simple.
I made the transistor angry.
Steve Mavronis
#7
I use the pin headers that have the grooves so you can snap them off 3 pins at a time. Then I can mount plastic transistors into them. You end up with it looking something like my illustration below. The photo shows it better after I figured out an easier way to bend the legs to get closer to the board. See tip below:
Tip: To spread the transistor legs perfectly without ugly crooked bends do this; take an old PCB with at least 3 holes drilled in a row spaced 0.1" (100 mils) apart. IC pad spacing is good for this. Slightly spread and feed the 3 legs through the holes and push down to the height above the header you want. Straighten the legs sticking out on the other side of the board you used as a spacing template. Remove and trim the legs to desired length!
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
dano12
Why not build the whole circuit on a socket?
egasimus
LucifersTrip
Quote from: dano12 on September 21, 2011, 01:08:39 PM
...and a turret board layout
nexekho
Oh, man, I've gotta try making some circuits like that.  Actually, would that slot into another socket?  Could a modular pedal be built with a row of sockets with standardised pin locations for ground, V+, V-, input, output to next stage?
Tony Forestiere
Quote from: nexekho on September 21, 2011, 04:53:40 PM
Search for the FXBus here. http://www.geofex.com/ . Pretty cool.
Steve Mavronis
Wouldn't you end up with basically a breadboard in a box?
nexekho
Goddamnit.  Every idea, beaten to the punch.  :/
@Steve
It'd be useful for onboard electronics in an instrument.
Tony Forestiere
Quote from: nexekho on September 21, 2011, 06:37:04 PM
A friend once told me "Hey. I wrote a new Blues song". I said "No you didn't".  :icon_lol:
