membrane potentiometers?
Started by FUZZZZzzzz, September 24, 2011, 08:43:46 AM
thedefog
Quote from: Jazznoise on September 24, 2011, 03:26:05 PM
These would act as some sort of ribbon controller! Could be good for those wanting a Fuzz Probe workalike or something of equally eccentric nature but avoids that nasty EMF!
I'd seriously consider attaching one or 2 of these to the body of a guitar, possibly wiring them to control tone or volume, or better yet to give it a seperate jack out and let it act as a form of expression pedal!
What about using a flex sensor?
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_150551_-1
FUZZZZzzzz
damn.. that looks great! do they work the same? price is even lower ;)
thanks for the link!
FUZZZZzzzz
Maximum resistance: 30k ohms to 40k ohms, proportional to the degree of flexing or bending
Nominal resistance: 10k ohms
Applications: virtual reality data gloves, robotic, bio-metric, physics and engineering (that sounds about right)  ::)
Length: 4.5"
artifus
#23
http://www.imagesco.com/articles/flex/sensor-pg2.html
also, if you have any conductive foam from past ic purchases and some tin foil or whatever laying around for a sandwich it's worth playing with for a quick and dirty variable resistance input to filter/noise circuits. check foam with multimeter for proxmity and compression variances. maybe mount in a door hinge for foot control? (you could vary resistance between hinged contacts with layers of foam, replace/dispose of 'spent foam' layers, etc...)
FUZZZZzzzz
