GTFO - Full tube high-gain pedal (2x 12AX7)
Started by gtudoran, September 25, 2011, 02:44:59 AM
Ripthorn
When you guys mentioned the inductor, I went and took a look.  Turns out that when I enlarged the hole in the pcb for the inductor leads, I cut the trace, so I had to have some solder on both sides of the lead and I was able to dial in over 300V.  I tested voltages with and without tubes, and all looks good so far.  Now I just have to try the whole thing all wired up, which I hope to do tomorrow.  Thanks for the suggestions guys, things are looking good.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
J0K3RX
Just fyi - I used an old 12v laptop or LCD monitor power adapter... It's rated @ 12v DC 4.5amps  I save power adapters from everything, I must have a whole box full of them, maybe 100 or more :icon_rolleyes: Ya never know when one will work for something... My wife tried to throw them away without me noticing and I saw them out in the trash, so I went out and grabbed them all and brought them all back in the house! :icon_twisted: Then I took all of her purses and put them out in the trash ha ha :icon_twisted:
fair.child
Quote from: Hilli on April 19, 2012, 05:40:05 PM
@fair.child: Wow, very nice PCB. That looks professional !!!
Thank you for your compliment Hili. Glad to know it.
It looks like you also can do fabricated PCB, if you want to built one again :), I would suggest to order it with http://www.seeedstudio.com/ I think they will sell you few of fabricated PCB with great deal. I realized that in my country to do fabricated PCB seems difficult, so seeedstudio option probably the best for get more professional PCB
Cheers
fair.child
Quote from: Ripthorn on April 19, 2012, 09:44:39 PM
Did you breadboarding or try to built GTFO with vero ? be careful. I've been 'shazam' (hot and stark) by this pedal, and It was really painful even just a little touch. Don't hurt yourself :)
Cheers
Ripthorn
Quote from: fair.child on April 20, 2012, 06:56:24 AM
Cheers
I have been working just on the populated PCB.  I was careful with the high voltage supply.  Previously I have never gone higher than about 150V in a project, but I am not too worried about this.
Groovenut
#205
Here is my contribution. I reworked the layout a bit, added board mounted pots and a shielded heater run on board. PSU yields about 325 vdc loaded. Fet and inductor get pretty warm. The finished circuit pulls about 600mA current.
Does anyone know if there are types of 555s that should NOT be used?
You've got to love obsolete technology.....
Hilli
Quote from: J0K3RX on April 19, 2012, 11:50:15 PM
My wife tried to throw them away without me noticing and I saw them out in the trash, so I went out and grabbed them all and brought them all back in the house! Then I took all of her purses and put them out in the trash ha ha
Great Jim. Hahahaha   :icon_mrgreen:  :icon_mrgreen:  :icon_mrgreen:
Hilli
#207
Damn Groovenut, that looks gorgeous.  :o
J0K3RX
Groovenut - That is beautiful! Love the board mounted pots!!! That looks sooo damn good bro!!! :icon_eek:
Groovenut
Thanks guys! ;D
I think on the next run I will put the backlight LED option, the effect LED, the jacks, and the switching on board as well.  :icon_twisted:
It's a fun project for sure!
fair.child
gtudoran
Well done Groovenut !  :o :o Could you share your modified layout for onboard pots?
Best regards,
Gabriel Tudoran
Analog Sound
Groovenut
Here is my modified layout for the board mounted pots. It is two sided but if you move the heater and 555 bridge offboard it's easily done single sided. Thus far I have not had any issues with noise, but I have taken extra filtering precautions to avoid it. I should have it in an enclosure soon and then will follow with pics. Thanks for the interest!
J0K3RX
#213
Lawrence,
Very nice!!! Could you post the black and white transfer of the bottom side? Please.. :icon_wink:
Edit: Pretty Please With Solder On It? ;D
Thanks,
~Jim
Groovenut
Quote from: J0K3RX on April 21, 2012, 10:48:54 PM
Lawrence,
Thanks,
~Jim
Here you go Jim. I dont know why it shows up so freakin big? It should be 3" wide at 300dpi.
J0K3RX
Groovenut
Also, is there any reason the pull up resistor for the BJT was left out?
Monitors display at 72, 96, 120 etc nominal DPI.
Generally printers have at least 4X to 3X the resolution of monitors. 300dpi is common. 600dpi exists. (Higher numbers in low-price printers are probably trickery.)
I measure your '3 inch' as 10.3" which works out to 87 dots per inch. Windows says it's thinking 96 dots per inch. Maybe my ruler swelled in the rain. Not worth trying to figure-out Windows' teeny mind. (Ah, it may be thinking 15" monitor, it's really 17".)
Groovenut
Quote from: PRR on April 23, 2012, 12:43:03 AM
Thanks Paul,
Hopefully it wont cause anyone any issues.
Groovenut
#219
Quote from: Groovenut on April 22, 2012, 09:42:00 PM
I just received verification the BJT pullup resistor was indeed unintentionally left out of the original. Actual value is 68k - 100k.
Here are the updated layouts
