Capacitor sub in Rebote delay
Started by alpeperker, September 28, 2011, 07:09:16 PM
alpeperker
This should be a simple one. I'm building the rebote 2.5 from tonepad. http://www.tonepad.com/getFile.asp?id=98
as i was soldering i realized that i didn't have any 0.082 uf caps left. now the question is, can i just use 0.1 uf caps instead, or would that cause problems?
the input cap, shouldn't be a problem, but i dont have the slightes idea in the other two connecting 9/10 and 11/12.
best regards, marius
anchovie
0.1uF is fine in those positions - they'll shave off a tiny bit more treble from the delayed signal but your ears might not even notice!
LucifersTrip
if that's the only value you don't have, you should easily be able to get .082 from the other values you are using in the same build. for instance, 3 x .027 in parallel = .081
always think outside the box
alpeperker
thanks guys!
i'll see if i have enough .027 s or else i just use the 0.1 s.
