capacitance meter
Started by LucifersTrip, October 06, 2011, 11:44:09 PM
frank_p
LucifersTrip
measuring a vintage 1pF cap.
always think outside the box
robmdall
Nice. Ordered the kit from Amazon today.
.Mike
Just want to add in that I have one of these, and they work great. I bought it from Seeed in 2009. They're all the same kits, I think.
It was a fun and easy build. The switch mounting posts were a bit too wide to fit into the PCB, so I had to file them a bit.
Also... center POSITIVE... heh.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
iccaros
cool, Have it on order from Amazon.. I get free two day shipping with them.. :)
frank_p
For people in Canada (even cheaper (?) ):
http://www.robotshop.com/ca/productinfo.aspx?pc=RB-See-35&lang=en-US
Tempted...
Thanks LucifersTrip !
CodeMonk
Quote from: LucifersTrip on October 07, 2011, 01:40:47 AM
that's cool...might be worth it since you get the fun out of the build.
how about this one:
http://www.seeedstudio.com/depot/capacitance-meter-kit-p-268.html
Just ordered this.
10 - 30 days shipping. $3
Can't wait.
After testing 200 caps today with my meter, which considering its from RadioShack, is pretty accurate for resistance, its cap measuring leaves a bit to be desired.
I usually put 20 or so caps on my breadboard all in parallel.
Then its : Measure. Remove cap. Measure. Remove cap, Measure, etc. etc. ad nauseum. Then get the differences between each reading and...you know.
Works that way but its a real PITA.
rogerray
I'm really tired of finding such cheap Chinese cap meters. I bet you'll know in the end that a LRC meter from Fluke, Tektronix or HP is the best choice. Not expensive at all for second hand.
pinkjimiphoton
harbor freight has a decent digital WITH cap and tranny testing etc for under 30 bux.
Slava Ukraini!
~Jack Darr
iccaros
pinkjimiphoton
nope, this one bro:
http://www.harborfreight.com/ac-dc-digital-multimeter-37772.html
for the price, one of the better meters i've used
Slava Ukraini!
~Jack Darr
tubelectron
Quote from: LucifersTrip on October 18, 2011, 04:53:33 PM
LuciferTrips,
I read something like 0.98pF... How much do you read when there is no cap to be measured ? Is there any zero-calibration on it (residual capacity cancelling) ? Even if finally it is not of a major concern for us, the accuracy (0.01pF !) seems to me very questionable, but I may be wrong...
A+!
http://guilhemamplification.jimdofree.com/
.Mike
Quote from: tubelectron on October 22, 2011, 06:18:24 PMI read something like 0.98pF... How much do you read when there is no cap to be measured ? Is there any zero-calibration on it (residual capacity cancelling) ? Even if finally it is not of a major concern for us, the accuracy (0.01pF !) seems to me very questionable, but I may be wrong...
There is a zero button to the left of the big IC, marked "zero". The instructions recommend that you build it into a metal enclosure so that it minimizes stray capacitance. :)
Mike
LucifersTrip
the pic shows .9P
yes...as .Mike  wrote.
I don't know the exact accuracy since I do not have a control. I measured many marked items from 1pF to 1000uF that were close enough to the case marking, so good enough for my use in building fuzzes. I don't need super accurate now, especially since the caps I use are many times off by 5-10%
tubelectron
QuoteThere is a zero button to the left of the big IC, marked "zero"
Ah, yes - I see it. Nonetheless, interesting device...
QuoteI don't need super accurate now, especially since the caps I use are many times off by 5-10%
In our pedals, that's usually way enough... Reasonable super accuracy out of a laboratory would be 2% on the usual values (say from 100pF to 10µF, with adequate measurement conditions). In fact, what is more important is repeatablilty of the measurement. I mean : if you measure 10 times, you find 10 times the same value at 1% accuracy - this lets you make seriously selecting capacitors.
A+!
robmdall
Ordered mine from Amazon with some other stuff - free shipping (~ 5 days). About 40 minutes to assemble - works like a champ!
Bob
CodeMonk
Quote from: CodeMonk on October 21, 2011, 06:48:26 AM
how about this one:
Just ordered this.
Can't wait.
Got the kit in the mail today.
Didn't have an enclosure though.
But I did have some plexiglass, a band saw and a torch.
Works pretty good so far.
DavenPaget
Quote from: CodeMonk on November 04, 2011, 04:55:49 AM
how about this one:
Just ordered this.
Can't wait.
Can you help me measure the board size ? I can't find the specifications anywhere .
Hiatus
CodeMonk
iccaros
Nailed mine to the wall, right over may parts bins. With this and my $1.95 harbor freight meter I can test parts before I take them to the work bench.. Now I need an inductance meter..
