Circuit not working when Voltage implemented
Started by AudioMime, October 21, 2011, 10:09:31 PM
AudioMime
Dear Diystompboxes.com,
After a long time of lurking and working, I finally started a very simple beginner project. For a while now, I've heard of Devi Ever(effector 13) distortions and fuzzes, and I learned that they have very minimal parts, so I thought that this would be a nice entry point. So, I slapped this john up on the breadboard and finished that within ten minutes. I compiled a quick perf layout and soldered the whole thing together.
The problem:
AUDIO MIME
Quote from: rousejeremy
Stick the Tremulus Lune in a Feedback Loop and your neighbors will call the cops on you. Which will be awesome.
AudioMime
Whoops! I guess that it deleted itself.
The problem : When I connected my one spot to the board, it creates a very loud hum.
When I connect a 9volt battery, there is no sound at all.
No power connected, the gain and volume still affect the clean signal, but no gain is created.
Voltage readout:
C: 3.00
B:   .60
E:  0.0
Notes : The 2.2M resistor that is in parallel with the .1 capacitor,was  changed to a 3.3M resistor.
http://www.diystompboxes.com/smfforum/index.php?topic=93686.0
AUDIO MIME
Input, output, or power connections incorrect.
