Offboard wiring without using a switch
Started by SomeNoob, October 26, 2011, 06:35:31 AM
SomeNoob
Quote from: deadastronaut on October 27, 2011, 04:22:35 AM
you want 2 x  4.7 uf's...the can type ones with a positive and negative for this.... not pf's...(lentils..that made me laugh.. :icon_mrgreen:)
Lentil is what they call them in my country  :D Anyway,
can type capacitor under 47uf is what i mean, i'm not sure if i can get of them. So if i have to replace these to caps with can types, should i just replace them with a 47uf?
4 . 7  uf's........   4 point 7...
what country?..
find an old radio or something and rip em out of that ok..... ;)
SomeNoob
#42
Quote from: deadastronaut on October 27, 2011, 04:34:36 AM
what country?..
Turkey
what do you mean by 4.7uf?
old radio okay... but how much old  :D
SomeNoob
Quote from: deadastronaut on October 27, 2011, 04:40:47 AM
::)  read the @#$%ing parts list dude!... ;D
http://tonepad.com/getFile.asp?id=86
okay sorry  :)
Alright then ill try to find an old radio then, ill be back here when i'm done thanks for the help!
no problem, good luck with finding an old radio/stereo with those in...they will probably be in there ok... :icon_cool:
SomeNoob
That didnt do the trick Doc,
I've replaced the two caps with can-caps, 4.7uf. Nothing comes out of the amp just a very very weak static.
Is there anything else i can do?
Main.Ace.FX
exactly how many parts have changed values from the original parts list....where did you get these parts from?
SomeNoob
For the resistors, only 1 resistors value is slightly lower (5k2 or something like that instead of 8k2)
2 capacitors, 0.01 and 0.1 are replaced with a 10 times higher cap (0.1 and 1)
Log. pots are replaced with linear ones.
And the transistors are not germanium, they are silicone.
I got these parts from a small electronics shop.
artifus
do you have a multimeter available? if not you could put together a continuity tester with a led, resistor and battery. check all connections and for shorts.
Main.Ace.FX
don't worry about the resistors, the change in value will be ok
I would try to get the capacitors closer to the correct values.... the .1uF should be ok for the .01, but replace the 1uF with another .1 (if you can use the required values, that would be best)  different values will change tone, but i've found in the past that changing them too much will make the circuit inaudible.
check your transistors again....do the emitters on all three face the bottom and go to ground?  make sure the collectors and bases are soldered to the correct holes also
check your grounds again...make sure everything that needs to be grounded all connects together.
you will need to do a continuity test if all of this is correct
SomeNoob
Quote from: artifus on October 28, 2011, 09:07:23 AM
I checked every single part with a multimeter right after i soldered them, each of them.
Quote from: Main.Ace.FX on October 28, 2011, 09:10:49 AM
I'll try to find the exact values for the caps tomorrow. I'm sure about the transistors, the emitter is on the right slot.
I did the offboard wiring exactly as you told, everything that needs to be grounded is grounded now.
How do i do the continuity test?
artifus
#52
but before you do any of that: take a break. get some air. go for a walk. have a coffee. chill.
when you return with a clear head have an idiot check (here i am! check!). it's often easy to overlook the 'obvious' stuff. i was debugging for hours the other day when i eventually noticed that my previously good jack to jack cable had decided to develop an intermittent fault. then look over your circuit again referencing the schematic.
*edit*
QuoteHow do i do the continuity test?
set your multimeter to continuity. it should beep at you when you touch the two probes together. attach one probe to ground. touch the other probe to all other ground points, one by one, and you should hear a beep if the connection is good. then check to see if anything beeps that shouldn't. hint: signal should not connect to ground (beep!). signal input jack tip.
SomeNoob
Quote from: artifus on October 28, 2011, 09:40:15 AM
Well i wish i could take a break and think about all this but... I barely have a knowledge about electronics  :)
I just know about the basics, some parts, how they work and stuff. I dont even know how a transistor works  :D
artifus
the trick is to take a break and not think about it!
Main.Ace.FX
SomeNoob
I am relaxed  :)
But i dont know what the problem could be, as i said, and dont know much about electronics, for me, its pure magic  :D
But the next thing ill do is to find the proper parts, at least the 0.1 and 0.01 caps. Hope thisll do, otherwise i'll be out of choices.
artifus
knowing it's magic is all you need to know.
look at the schematic. look at your circuit board. compare and contrast.
imagine yourself as an electron. you were created by the guitar and you desperately want to meet ground. but you've gotta make your way thru this circuit in order to get there. what would you do? in which direction would you flow? would you make it to the output?
LucifersTrip
This is a fun read and I hope SomeNoob is learning something, but I honestly don't know how this thread has gone so long while completely ignoring the debug thread
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
from the beginning, it was never about "Offboard wiring without using a switch". It was about debugging a circuit. I do not believe SomeNoob
ever stated that it actually worked
SomeNoob, since you have a multimeter, the voltage readings would be a cool starting point
good luck
always think outside the box
