"Blushing" under decal
Started by swinginguitar, October 31, 2011, 09:25:37 AM
swinginguitar
I was doing my usual stompbox decaling this weekend, and on one of them, there are some areas that are cloudy - almost look like lacquer does when it "blushes".
Any ideas why? I did 2 boxes and one of them did this and the other didn't.
Did i not clean the one well enough?
Decal too dry? Should I have wet the enclosure out a little more before applying the decal?
Maik
I think there was some dirt on it.
When the decal is taking out of the water and getting rid of the paper, it´s wet enough.
I try to get rid of the blushes one hour after getting it on the box, but I use the ceramic ones witch must be baking in the oven for 45min.
swinginguitar
on closer inspection, it appears to be scratch marks.
I wet sanded the paint with 800 grit to smooth out dust nibs etc before decaling. I didn't think the 800 grit scratch pattern would be visible...grrrr
siore
Some elbow grease, and some rubbing compound to eliminate those fine scratches.  Or you could just apply another coat of lacquer.
