If These Were Yours..Pedal order opinions, please..
Started by AS74, November 08, 2011, 09:28:14 AM
AS74
Hello to all generous n wonderful folk here!
Looking to rearrange my pedal board and would like to know the different ways folk would arrange (order) these pedals if they were theirs.
I'd like to optimise cable lengths to be as short as pos.  As things are at the moment there is excess cable usage..so after some opinions I'll sort positioning for this purpose.
Being:
Fuzz Face Ge
Big Muff
Phase 45
Dyna Comp
Dunlop Wah (no buffer)TB
Axis fuzz
Octavio
DOD250
Tube Screamer
Guvnor Plus
Rebote Delay
ABY.
Thanks....:)    Also, can someone point me to where i can buy mogami/canare cable in Aus. or online (shipping's always a killer). For diy patch etc..
I hope I don't come across as arrogant or rude, I truly respect the community here. Helps so much, in more ways than one.
Quackzed
wah
fuzzes ,oct
comp
od screamer guv
dist 250 bmp
phase
delay
--the aby would be useful organizing all the od/dist pedals... maybee one side gefuzz/scrreamer/250 other axisfuzz/guv/bmp maybee... with the comp before the aby... and a mixer stage after to get a and b back in the single signal chain...
AS74
joelindsey
I like to put my wah before fuzzes, that way when I use them both at the same time the wah won't make my ears bleed at the forward position. I put my compressors before fuzz as well, since the fuzz will compress your signal anyways. My compressor gives a little high end boost, which is nice when it goes before my Tonebender. I guess placement all depends on how/when you use them though. That's just what I like.
Why are you worried about cable length? If patch cables are piling up like spaghetti that's one thing, but if you already dig your sound I wouldn't worry it.
Ever see a band called Tame Impala in Perth? Ha!
