'SPITFIRE' Metal 'n' Blues Pedal...
Started by deadastronaut, November 10, 2011, 11:18:58 AM
Perkla
Quote from: deadastronaut on December 30, 2011, 02:20:59 PM
yeah, it''l be fine...in uk we have 47k's..in usa etc  they have 50k's...
same as 470k/500k...etc...  just the way it is..
again you might wanna hold fire and wait for the version 3...less switches, and better imo...
i'll post it up later or tomorrow ok...i'm just trying to find a @#$%ing on on on switch arghhhhh...... :icon_rolleyes:
OK cool.. well, yes if u can provide a sound sample of the version number 3 maybe that is what i want to build.. i am gona order some stuff so.. just let me know what components it have and i order than at the same time.. :D
get a on/on/on switch for sure....
i can't find one in my bitsbox..arghhhhhhhhhhhh....off to the shops tomorrow...if they are open.. ::)
all other components will be standard stuff...just one more cap ...
Perkla
Quote from: deadastronaut on December 30, 2011, 02:26:56 PM
Ok i´ll get an on/on/on switch.. i have most of the standard stuff so i hope i have everrything else..
But would be cool to see a wiring diagram on the version 3.. just to have a look what it looks like.. :D, and hey.. btw, in the version two, isnt it possible to have an ON/ON switch for the VOL 1 bright and VOL 2 darker ? i mean so it could easy be switched between the both modes ? just a thought though..
you could do that yep...but when you build the pcb try both outs first to see which you prefer..
i'm all for the simple life.. :)
Perkla
Yes.. ok.. thats what i had in mind, and i kind of like switches that change the sound, but i am all out on developer so i cant etch eny PCB´s now.. need to order that to :D
Well u mean that i could build both the version 2 and 3 ? or what did u have in mind ?  :icon_biggrin:
i would build 3..., you'll still have both outs if you like too...optional.
i'll knock it up asap, my family have just turned up from miles away, so i'll have to squeeze it in when i can... ::)
Perkla
Quote from: deadastronaut on December 30, 2011, 03:01:30 PM
Thats awesome.. i´ll wait and see what happens..
What amp did u use in the demo of this pedal ?
Perkla
Quote from: deadastronaut on December 30, 2011, 03:16:48 PM
no amp, straight into a mixer... :icon_cool:
Thats cool.. cus a amp sounds different to.. if i test a pedal in a music store that i like and i was playing it on a JCM 800 and comes home and hook it up to my Marshall MG15 ministack it will not sound the same..
Perkla
Ok so i am doing a little thing here.. the PCB will fit in to a B enclosure.. BUT with the 24mm pots and IF i wanna have 9 volt battery in it.. i am @#$%ed... it will not fit in to a B box.. impossible..or ?  have u checked this up anything ?
My attempt
i never use batteries......and only use mono jacks..
and whoa!...those are big pots...i use 16mm pots..then the middle pot can face backwards...
you need room for a dc socket too..and a toggle switch.... :icon_eek:
Perkla
Quote from: deadastronaut on December 30, 2011, 05:23:31 PM
I was just curious about if its possible to have a battery in a B box when building a Spitfire..we maybe i can use a B box.. but no battery will fit in.. so it will only be 9 Volt DC possibility..
Perkla
The 16mm is not easy to ge my hands on over here.. :S in 99% of my builds are 24mm so thats why i almost only use them..
J0K3RX
Looks like a magic trick getting a battery into that box...?  I use 125B 4.77" x 2.6" x 1.39" enclosures most of the time just because they are deeper and I don't like fighting to get all the guts inside, plus it's only like .25 cents more so... I am sure you could get it to fit inside but you will have to pull some slick mojo... I would just use a 9V external power jack like Rob said... Is there a reason why you want to put a battery inside? You know, you can always solder a 9v battery snap connector to a DC plugin connector and use it external if you have to use a battery. Anyway, you are gonna love this pedal!!
Rob - Nice job on the new layout :icon_biggrin:
Perkla
Quote from: J0K3RX on December 30, 2011, 07:29:26 PM
No.. no reason to use a B box.. just a tought if its possible, i will use a 125B enclosure for sure.. :D, Yes a external battery clip is possible.. :D
J0K3RX
#115
Rob, I made a board transfer for your second rev. with 1 switch, hope you don't mind :icon_question: It's really large so if anybody wants it they can re-size... I left in the ground plain so you can get a little more out of your etching solution... Happy New Year!
WGTP
I know it's late in the process, but the BSIAB II uses the 3rd jfet as a gain stage rather than a buffer.  So if you want more gain...  ;)
http://www.generalguitargadgets.com/pdf/ggg_bsiab2_sc.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Stomping Out Sparks & Flames
J0K3RX
#117
Quote from: WGTP on January 02, 2012, 05:32:10 PM
WGTP
Does it have more gain than the spitfire? I have seen that one but have not built it, yet...
~ Jim
i built that bsiabII^ , i couldn't get on with it, it was too muddy imo, thats why i explored it further.... :)
WGTP
#119
I'm not sure how to measure or calculate the gain of the 2.  I think the bypass caps in the stage has allot to do with it, the resistance between stages and the number of stages.  For max gain, use big bypass caps, 22uf, minimize resistance between stages and use 3 of them.  That could present some problems with too much gain, not sure.  ;)
Here are some suggested gain mod to try.   :icon_twisted:
http://www.aronnelson.com/gallery/main.php/v/WGTP/Spitfire+Mods.jpg.html?g2_imageViewsIndex=1
