'SPITFIRE' Metal 'n' Blues Pedal...
Started by deadastronaut, November 10, 2011, 11:18:58 AM
Ronan
The problem with more gain is less definition, less of the guitar tone itself coming through. I think the Spitfire is a good balance. You could destroy what you got by adding more gain, or maybe not, depending on what your ears wanna hear.
WGTP
Yes, I'm not saying all those mod's will work, as apposed to creating an oscillating mess, those are standard methods of increasing gain.  Some designs produce 2 stages maxed out, others 3 stages with less gain in each stage, but about the same overall gain for the devices.  When designing for max gain, a point is usually reached at which additional gain will cause the device to be unusable.  ;)
I forgot to add that resistance can be added between stages to reduce gain.  This is commonly used int tube amps. :icon_mrgreen:
Stomping Out Sparks & Flames
right, heres version #3 . i kept it simple in the end......a bit like me.. :P
using an spdt on/on switch...to go between modern/classic...socket c10/c11 to taste.......
http://dl.dropbox.com/u/7464107/SPITFIREV3.pdf
http://dl.dropbox.com/u/7464107/SPITFIREV3PCB.pdf
pcb's available soon if anyone is interested, pm me ok.... ;)
euronymous0001
Perkla
Looks great.. :D
Do u have a demo of this pedal ? on youtube maybe ?
 :icon_eek:....its the same as this but with the sustain boost on permanent, and blues on permanent...
with just modern/classic as in the video.....simplified after a few weeks of using it... :)
from 7:33.
Perkla
U are a damn good guitar-player.. i must say, sound good.. :D
The V3 sounds awesome.. and less SPDT ´s than the V2.. :D
cheers man!....yep kiss (keep it simple stupid)...is the way to go.. ;)
spam alert! :o
spitfire pcbs ready guys. (fits 1590b)  sorry for the wait, i was waiting on an etchant delivery.. ::)
i found out the average airmail post worldwide is £1.50 +£6.00 per pcb.=  £7.50 GBP total.
paypal at deadastronaut@yahoo.co.uk if you would like one..
i'll post  orders out on saturday 14th jan...if ordered by friday 13th night ok..
any questions pm me .. ;)
Perkla
Quote from: deadastronaut on January 11, 2012, 07:53:12 AM
spam alert! :o
Looks great, do u etch yours in a etching tank ? do u use OH and photopossitive copperlaminate ?
Govmnt_Lacky
Looks GREAT Rob but...
I'm gonna hold off until the 1590A version shows up  :icon_eek:
i dont do 1590a's...i haven't got tiny feet... ;)
@perkla:  laser toner method:
J0K3RX
Rob ~ Nice looking etch and drill! I like using DIY Layout Creator, quick an easy... I like to leave as much copper as possible on mine just to save ferric chloride etching solution... I know some people don't like it if their solder skills are shaky and are prone to creating solder bridges/shorts etc... But I like it.
J0K3RX
Rob ~ Here is one I did  from your layout but with on-board pots.. less wire :icon_wink: I don't have the parts layout but it's pretty much the same as yours, a couple things have moved a little but nothing that somebody couldn't figure out... This was for my own personal use, not going to sell them!
http://dl.dropbox.com/u/11178619/Spitfire%20v3.1.34%20transfer%20onboard%20pots.bmp
@jok3rx : nice work man!.
i like to have my pcbs a bit more open plan, for shaky dudes with dodgy eyes like me.... ;)
@Ian.W.B.  thanks. will post saturday with other orders ok.
edit:
@Al .S.  thanks. post saturday ok.
edit:
@R.V.  thanks. post saturday ok .
WGTP
Here is a shot of the frequency response of the tone control set at modern, with the 50k pot in the middle.  A 100k pot lowers the midrange notch down a little and cuts more of the treble.  ;)
http://www.aronnelson.com/gallery/main.php/v/WGTP/Dead+Astro.jpg.html?g2_imageViewsIndex=1
J0K3RX
#137
Hope you don't mind me doing this Rob... I just love this pedal!!! :icon_biggrin:
layout with the onboard pot differences
See diagram below:
dl.dropbox.com/u/11178619/Spitfire%203%20%20onboard%20pots%20layout%20daigram.jpg
Standard Layout differences
See diagram below:
dl.dropbox.com/u/11178619/Spitfire%203%20Standard%20layout%20daigram.jpg
Board Transfers:
Onboard Pots - open layout without the ground plane for those with unsteady hands and poor eyesight
dl.dropbox.com/u/11178619/Spitfire%20v3%20onboard%20pots%20open.JPG
Onboard Pots - With ground plane fill to save etching solution
dl.dropbox.com/u/11178619/Spitfire%20v3%20onboard%20pots.JPG
Standard layout no ground plane for the elderly...  :icon_razz:
dl.dropbox.com/u/11178619/Spitfire%20v3.1-1%20open.JPG
Standard layout with ground plane fill to save etching solution
dl.dropbox.com/u/11178619/Spitfire%20v3.1-1%20transfer.bmp
J0K3RX
Quote from: WGTP on January 12, 2012, 10:31:34 PM
I will give that a try!
Jorge_S
I think it will be a good idea to move the design files to the wiki, with a "mods" section. This pedal is great!
