'SPITFIRE' Metal 'n' Blues Pedal...
Started by deadastronaut, November 10, 2011, 11:18:58 AM
Quote from: escroito on April 09, 2014, 10:37:19 AM
is there a current version circuit somewhere handy?
" I will say no more "
thanks, DA (the other). so, looking at the layout posted above, the parts numbering doesn't seem to quite match.
no it doesn't perrow did that curly one a while back..
Perrow
I thought that was for the V3 but I might be wrong? I think I matched the parts numbers for the version I used as reference and I think it was a version d'Astro never did build. I etched and populated an earlier version of that board that copied the posted layout which had a flaw (so my 1590A version did too) and I never got around to etch another.
I'd look at my layout in DIYLC but I haven't installed it since upgrading my computer and I just have to get to bed now. Maybe I can look it up tomorrow evening.
Perrow
Quote from: deadastronaut on April 26, 2012, 02:57:59 AM
here ya go ...sorted...good catch man!.. ;)
http://dl.dropbox.com/u/7464107/SPITFIREV5THRASHER.pdf
http://dl.dropbox.com/u/7464107/SPITFIREV5PCB.pdf
T'was V5 I modified. Some caps aren't numbered in d'Astros layout, but you can deduct which one's which from value and parts list.
That layout is not verified but neither is it disproved.
Luke51411
I built V3 today. This thing rips! Thanks for all your hard work DA. I built it on the vero layout in the tag board request forum. It can be found here: http://guitar-fx-layouts.42897.x6.nabble.com/Spitfire-Metal-n-Blues-Pedal-from-DIY-stompboxes-request-td8893.html#a8991
SmoothAction
Yep, it rips. DA did a super job on this circuit, my buds are hounding me about the sweet toanz of this pedal. I just tell em to build one themselves out of respect for DA, I won't be selling mine or any multiples.
Waiting for robs 3 band eq version. The single tone control works nicely but I'm amped to see his reincarnation of this wicked beast. Puts my bsiab2 in the dog house for sure.
"Never heard a man speak like this man before, never heard a man speak like this man before. All the days of my life ever since I've been born, never heard a man speak like this man before."
Luke51411
I can't wait to get a chance to play with this pedal some more. For V3 is there much difference from V1 other than removing the hi boost/cut switch and the blues/funk switch? I'll look at the schematics side by side when I get a chance. Would it be worth adding these switches to my build or was there a good reason they were removed? Ultimately I'll have to try it for myself just wondering about other opinions. Thanks.
cool glad your enjoying it... :icon_twisted:
i removed those option just for a simpler build...i settled on the one i liked and left it at that...
rob,
Luke51411
So I plugged my build into the breadboard since I don't have it boxed yet and I couldn't figure out why it was so quiet as it was quite loud when I tested it after first building. I cranked the gain and volume still not very loud though it sounded good. Upon checking connections i discovered that I had plugged the output of the circuit in to the adjacent strip to where I plugged in the output jack. I was surprised at how much signal came through without actually being connected :icon_twisted:
J0K3RX
Hey Rob you still have this on the bread board? I am curious to how this will sound..?
Hi jim , yep i still have the stackless one on breadboard,  if i get time tomorrow ill try it man...
J0K3RX
#533
Here is "straight up version 3" done with Diptrace..  Not the most beautiful but gets the job done! :icon_twisted: Needs some silkscreen touch up..
Sweeto...im still getting my head around eagle...i,m at the point of sorting out the gerbers etc....bit by bit...in between other stuff.... :icon_rolleyes:
SmoothAction
Nice jok3rx! I am a huge fan of all robs work here. A real go getter he is. There are so many circuits that get excessive love... This spitfire is criminally overlooked in the metal world for sure. I fekin' love mine. It needs a fabbed PCB, with DA's blessing of course. Sweat and blood is obvious here. I'm just a lonely diy'er for sport, but this one has me hooked.
BUMPED BECAUSE IT NEEDS TO BE BUILT.
347sixtyseven
Hi guys,
I just completed a build using the layout the Ozsi posted.
With basic ancilliary wiring it worked beautifully but i have just boxed it up and am having problems.
When a battery is connected the pedal produces a squealing noise even when the effect is bypassed. (standard 3pdt,led,9vdc socket wiring)
I have triple checked everything and cant see anything that would be causing a problem. Please note that the 3 position switch and the gain pot cause variation of the sound. Also if the board is lifted from the enclosure and moved around the noise varies (sounds like a theremin almost).
Any suggestions or direction to obvious problems would be greatly appreciated
Cheers
Gary
Luke51411
I had the same thing. I fixed it by using shielding wire on the input and output. Make sure to connect the shielding to ground .
347sixtyseven
Luke, thank you for your reply, did you have the problem before you put the circuit into your enclosure or after?
Only asking as mine performed perfectly just as a bunch of components and wires on the floor, only started playing up when put in the enclosure?
I will try shielded wire though.
Luke51411
It worked good the first time before I boxed it then when I pulled it out to troubleshoott it squealed sometimes depending on wire positioning. I think I shielded the wires to the classic/modern switch too not sure if that was necessary but it works now.
