MPF-102 Transistor Bias
Started by soupbone, November 12, 2011, 07:07:38 PM
soupbone
I found a circuit that uses 1 MPF-102 tranny.It says on the build doc to "bias" the transistor for 4.5v.Anyone have any info on how to do this?
smallbearelec
Quote from: soupbone on November 12, 2011, 07:07:38 PM
There should be a trimpot in the drain circuit of the transistor. With your meter connected from drain to ground, tweak that pot till you see 4.5 Volts.
soupbone
#2
Quote from: smallbearelec on November 12, 2011, 07:19:30 PM
Cool!This layout doesn't use a trimpot.Should i adjust the resistor,If need be that is connected to the drain of the transistor?
frank_p
Quote from: soupbone on November 12, 2011, 07:41:52 PM
Choose trimpot to higher value than the drain resistor on your shem.
Replace the resistor with trimpot like this:
adjust to 4.5v
Than if you have it, replace with close value resistor or leave trimpot.
Measure, try to play.
http://www.runoffgroove.com/fetzervalve.html
http://www.hawestv.com/amp_projects/fet_preamp/fetpreamp6.htm
soupbone
#4
Quote from: frank_p on November 13, 2011, 12:00:08 AM
Oh ok,So you just replace the resistor with a trimpot instead.Excellent!Thanks!
adjust to 4.5v
Oh ok,So you just replace the resistor with a trimpot instead.Excellent!Merci!
soupbone
Thanks Steve for the info!
diydave
If you don't want to use a trimpot for the drain, maybe these rules-off-thumb can help.
Vp/2 gives Idss/4.
Check out runoffgroove's fetzervalve to get the Idss (max current with gate=grnd) and Vp (pinch-off-voltage) off your fet.
So you can calculate a source-resistor Rs = (Vp/2)/(Idss/4).
To bias for 4.5 volts at the drain, you need a drain-resistor Rd = (4.5 volt / (Idss/4) ) - Rs.
I've written a calculator + Vp/Id curve as a visual aid to bias fets.
You can find it at www.diydave.be/tools/fetcalc/index_eng.html
soupbone
Quote from: diydave on November 13, 2011, 04:32:11 AM
Vp/2 gives Idss/4.
Wow Dave thats some great info!Thanks!
