Adding a control for fuzz to a DAM Meathead
Started by jacobcarpet, November 17, 2011, 09:33:21 AM
jacobcarpet
Just experimenting with fuzz pedals, and wanted to add a control to lower the fuzz on an experimental DAM Meathead. It's just a tagboard experiment, and I'm using this layout.
http://tagboardeffects.blogspot.com/2010/02/dam-meathead.html
Anyone have any suggestions? I've already added a tone circuit via a layout for the Big Muff Pi tone control I found in a quick google search.
Thanks for any suggestions.
Jacob
roseblood11
It's a fuzz face...
And there's a thread about all the different versions of the Meathead, including those with three knobs, over at the forbiddenforum
nocentelli
Weirdly, this exact same question was asked there also in the workbench forum: Here's what I said -
The Meathead is a fuzzface (with a couple of value changes and some tiny caps the base + collector on both trannies to smooth that silicon harsh) so to add a fuzzface gain pot, just remove the Q2 emitter resistor (1k) and  Q2 emitter cap (10u) and replace them with a 1k pot with lug 3 wired to the Q2 emitter, lug 1 wired to ground, and the 10u cap wired between lug 1+2 - The max gain will be the same as the stock Meathead, but you will be able to lower the gain.
jacobcarpet
Thanks I'll give it a try. Sorry I didn't look in the other folders. I'll search a little more for more info. Thanks.
  The FF can't drive much, the BMP tone control has big passive losses. 'It' starts getting away from being a FF once a TC is added, perhaps a buffer to drive some current through the TC....
   Otherwise, FF gain control is worth a lookat, the *1k/AC bypass cap set the gain/frequency in the Meathead.
  Just a look is good though..because the guitar volume 'can' be a gain control with the FF. as shown with preset *gain, try using the guitar volume. A whole other thread about PU's and Control Pot values may or may not be the thing, also worth taking a lookat, before and after trying it out. It should clean up at the guitar volume control. The way the guitar/FF circuits interact can be altered to fascilitate improved tone/gain control.
