Has anyone tried modding a Pro Co Rat to run on 18V supply?
Started by Jasonmatthew911, November 18, 2011, 11:34:20 AM
ashcat_lt
Okay, got the point of those two last posts.  But the opamp does continue to swing to it's clipping point, and adds that bit more distortion?  Or do I not understand how these diode clippers work?   I've always heard that the opamp clipping and slew rate limiting are important parts of the whole Rat sound.
the_floyd
I can corroborate the whole Rat 18V thing - upgrade the caps and it's a noticeable improvement.
The way I've always understood it to work is the opamp distorts at a higher voltage threshold than the diodes, which then clamp the signal further as they're still receiving a "high-voltage," albeit clipped, signal.
