Easy Mid-scoop Control
Started by Bill Mountain, November 29, 2011, 09:42:02 AM
Bill Mountain
I wired this up last night because I wanted a variable mid-scoop in a fuzz I was working on.
This will go from a flat response to a 26 dB cut at about 400 Hz.
Moving the R's up will lower the scoop frequency (e.g. 22k ohm equals about 220 Hz)
Moving the R's down will raise the scoop frequency (e.g. 4.7k ohm equals about 1k Hz)
This is nothing revolutionary.  I've even seen Bridged-T notch filters like this discussed on DIYSB's before but I thought I would post one that worked well for me.
Good luck!
EDIT:  I think I'm going to try a 10k pot when I get home this evening.  With the 10k at max it may not have super flat mids but I think it will have a better ratio of turn to Db reduction (if that makes any sense!).
Bill Mountain
I plan on getting a dual gang pot to experiment with making the notch frequency variable but I usually get in trouble when I have that much tonal control.
cool: i'll try this later...nice one bill.. :icon_cool:
alparent
Did you draw those resistors during an heartquake?  :icon_lol:
Bill Mountain
MS paint with a mouse that sticks.  That was my third try.
Ice-9
Quote from: alparent on November 29, 2011, 12:46:02 PM
No, I recognize those resistors, there a special log to current vairable resistance.
I will give this one a try , thanks
digi2t
Quote from: Ice-9 on November 29, 2011, 03:14:42 PM
Also known as "Chicago" resistors.
Nice Bill. I'm kind of a fan of the mid-scoop. I think it harks back to the first time I heard a Boston tune  :icon_smile:.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
ayayay!
Pretty cool, thanks!  Reminds me of the Mid-Notch that STM posted a little while back.  Very similar low count type of thing.
The people who work for a living are now outnumbered by those who vote for a living.
@bill, just tried it...nice!...i swapped the 50k for a 10k...seems a better range over the pot sweep...nice!.. :icon_cool:
i bent my resistors to look like the diagram too... ;)
Bill Mountain
Quote from: deadastronaut on November 29, 2011, 04:49:13 PM
I was just thinking a 10k would work better.  Did you see my edit or did you try it on your own?
no i just tried it just now!....i used 10k resistors too....didn't have 12k's...
looking forward to the notch freq shifting version... ;)
Bill Mountain
Well I'm glad it worked for you.
I went home on my lunch break and tried it after a few of my dirt pedals and I thought it hollowed the sound out nicely.
Now we just need to find some 20k dual gang pots.
yeah just tried it after a distortion too, scooped it out nicely..very punchy..... :icon_twisted:
i'm not a fan of dual pots...limited knobs n all that....have you a scheme of the dual thingy then?...with wonky resistors too... ;)
earthtonesaudio
Another variation is the bridged differentiator:
Pot sweeps the frequency (although the bandwidth and attenuation will change as well).
DavenPaget
My Beta Aivin HM-200 surprisingly has a mid-scoop control ( They call it a mid-cut control )
from 200Hz to 5KHz ...  ;D
Although i could open it up and draw up a schem , i can't , 1 of the screw's chipped  :icon_evil:
Hiatus
PereatMundus
#15
Quote from: Bill Mountain on November 29, 2011, 04:56:25 PM
Hey, Nice stuff. I need to try this :)
btw dual gang pots, 20k.  you meen a simple stereo pot?
If so here is one:
http://www.banzaimusic.com/Alpha-16mm-stereo-20k-lin.html
edit: ah ok, no you whant notch freq variable. then check the below mouser numbers.
QuoteI plan on getting a dual gang pot to experiment with making the notch frequency variable but I usually get in trouble when I have that much tonal control.
and here is some dual gang 20k pots on mouser:
Mouser Part No:         652-PTD902-10BAPB203
                                652-PDB182-K420K203B
                                652-PTD902-2215KB203
Guitars: Westone Prestige 150 - Aria Pro II CS-400BnG
Amps: 5150 - SloClone
Fx: 20+ DIY (100+)
Play: Kraut/Death/Industrial/Noise
Pereat Mundus Et Furia Tempo-Leena Krohn/Schopenhauer
ayayay!
Quote from: earthtonesaudio on November 29, 2011, 08:29:50 PM
Something about that looks so fun.  I've got to try that.
Bill Mountain
Quote from: PereatMundus on November 30, 2011, 10:15:34 AM
If so here is one:
Seems like any of those would work.  I just need to include some in my next parts order (which sadly won't be until after Christmas).
Bill Mountain
This seems cool and unpredictable in a crazy/fun/awesome way.
PereatMundus
#19
Quote from: Bill Mountain on November 30, 2011, 10:33:28 AM
If so here is one:
yea, same issue here I seriously just added a mouser order yesterday..
(and an expensive one, parts for a SloClone and about 5 Fx boxes...   :icon_mrgreen:
So will have to wait to try this until Xmas or later for the next order.
However, as far as knobs to go with the dual gang pot I've always liked these below:
[Edit: that is of-course if you whant the dual/stereo pot with seperated control so you can use concentric knobs,   , guessing NOT cause you wish to vary the both resistor values  at the same time, no? ]
and here is a great hint. to make it nice.
the notch in both lower and upper control of the knob, take a drill and make a 1-2mm hole there instead, and glue a Led in that spot.
Mouser Part No:    755-SLC-22MG3F
                                755-SLC-22VR3F
                                755-SLC-22DU3F
these are GREAT for that due to their shape, able to press the flat top led through the hole and fasten it safely.
I've used this in the past when I REALLY whant to see the knob setting.
Its seriously cool looking and useful. particularly in stacked knobs.
http://www.guitarfetish.com/Concentric-Chrome-Knobset_p_174.html |  http://www.guitarfetish.com/Concentric-Knobset-Black_p_177.html
Fx: 20+ DIY (100+)
