Dr. Boogie Mini Creation
Started by tsxp, December 12, 2011, 06:54:58 PM
tsxp
Hello everybody,
I've been doing electronics projects lately, and I found this wonderful site with tons of information. I decided to try the Dr. Boogie, but with a SMD twist. I figured I'd share what I've done and see if you can find any problems with the build.
First, I went with the PDF here - http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=44055
I noticed there were two PDFs, this and one with tone control, so I figured I should go with this one since it had a later date. My schematic follows it pretty closely (if not right on).
http://i.imgur.com/mBnxa.png <-huge image warning
The board itself is 2.25" x 1.6", which is about the same size as the board in the pdf.
http://i.imgur.com/3XkUm.png <-huge image warning
I1 / I2 are input/output connections, which will be mounted off board. R6/R16 are volume pot/gain pot connections, which will also be mounted off board.
If you have any questions or any input, I'd love to hear it. I'm also thinking about making a monster box with multiple effects inside. If you would like to recommend any other DIY boxes, I'd appreciate it.
Thanks to everybody involved with the creation/modification of the Dr. Boogie project.
looks cool:  have you any soundclips of it so far?...
ive built a few dr boogies, great pedal, but if i built another i would most probably change the tonestack.  imo.
tsxp
I haven't had the board sent off yet, just in case I wanted a couple more things made. The overhead of making the current board is 2x the actual cost of the board in sq inches. I will definitely report back when I get the thing made.
On a side note, I plan on using film caps (most PPS). I would eventually like to see the difference between film and the ceramic counterparts. If the ceramic's sound good enough, it would probably take close to $10 off the project.
Quote from: deadastronaut on December 13, 2011, 05:03:03 AM
Do you mean remove the tonestack? If so, I'm using the schematic that has it removed.
