My DI Design
Started by a soBer Newt, December 13, 2011, 11:58:20 PM
a soBer Newt
So this is a DI that I built from the schematic for the output of a mic pre that I have. I love how it sounds now what if anything am I doing wrong? Should I include DC blocking caps on the front end or larger resistor to ground for a higher input impedance?
Sound Sample
http://soundcloud.com/a-sober-newt/bass-di-evan-1
Jarno
Did you use the schematic from the datasheet, thought that these drivers are usually in the feedback loop of the opamp (at least buf634 and LME49600)?
Gurner
Quote from: a soBer Newt on December 13, 2011, 11:58:20 PM
Whilst the technical purists might differ, from what I can see, what you've done is fine....you're using a bipolar supply, therefore there's gonna little (or almost zero) DC present at the first opamp +ve pin ...i.e. with a guitar plugged in (your pickup will bias the +ve pin to ground once plugged in). Adding a resistor would actually lower the input impedance vs what you have there at the moment (ie no resistor) ....that said without a guitar plugged in, the +ve pin will likely float up in DC a little....so if you intend switching in/out an input signal regularly, you're likely gonna get pops, so then biasing the input to ground with a 1M resistor should help.
a soBer Newt
Quote from: Jarno on December 22, 2011, 02:49:09 PM
The buf634 looks to be an unbalanced line driver where as the DRV 134 is a balanced line driver.
Quote from: Gurner on December 22, 2011, 03:00:30 PM
This I know may be a hard question to answer but would the pops come from turning on and off pedals in front of the DI or just inserting the cable?
Would this be a slightly better design at all, I changed resistor values a bit to what I have more readily available.
Screen shot 2011-12-16 at 4.36.21 PM by asobernewt, on Flickr
