To Combine 2 Circuits, Do you remove the Output/Input Caps? (ANSWERED)
Started by rwebbart, December 15, 2011, 10:08:18 AM
rwebbart
Sorry, I know there are a lot of "combine 2 effects threads" but I couldnt find one that addressed this specifically.
If I want to combine the 2 circuits in the top drawing, do I leave the clouded section in, or do I remove the output/input caps and pull down resistors and join them as in the second drawing? I know just hooking the input and output together would work, but are the extra caps necessary since the signal is already converted to DC and doesnt need to go back to AC until it leaves the second effect circuit?
Many thanks in advance for any conformation/correction and any elaboration on why!
egasimus
Quote...two join to effects together
:o
you, sir, are a criminal.
I'm not going to help you now.
rwebbart
Quote from: egasimus on December 15, 2011, 10:19:12 AM
Oh, wow... The worst part is, they both said "to" and I went back to "correct" it. If I said I was only on my second cup of coffee, so Im not quite awake yet, would that help?
blueduck577
Leave one of them.  Which one you want to leave is personal preference
rwebbart
Quote from: blueduck577 on December 15, 2011, 10:35:51 AM
Thanks, but can you briefly describe why so I can wrap my head around it better?
thedefog
So you're asking what is the purpose of the input/output cap and the pull down resistor?
Input cap acts as a high-pass filter - depending on the value in conjunction with a resistor to ground, you will roll off more or less of a frequency range. This is useful for taming certain effects and how they behave when they're amplified/filtered/etc.
The output capacitor is mainly used to block DC current. But they are sometimes used for filtering too.
Pull down resistor is for minimizing true bypass popping.
rwebbart
Quote from: thedefog on December 15, 2011, 11:28:18 AM
Thanks, but I get that. I was asking about where i have the drawing above clouded. Why leave the one (as the other replies suggested) where they are joined which will become the middle of the circuit, not the input or output.
therecordingart
#7
If you remove both caps you'll be applying DC from the previous stage to the next. By keeping one of the caps you are only passing the AC portion of the previous stage to the next stage.
If you remove the caps that is called DC coupling or direct coupling.
jafo
Both caps do the same thing; you only need one. It's not necessary to use both.
In fact, using both can be harmful, given the cutoff frequency of caps in series (the reciprocal of the summed reciprocals, or something like that).
I know that mojo in electronics comes from design, but JFETs make me wonder...
rwebbart
@jafo & @therecordingart
Ding! You just made the lightbulb go on. I get it now! I appreciate it much.
