max1044 question
Started by iccaros, December 19, 2011, 04:49:32 PM
iccaros
should I ground pin 5 when using this chip as a voltage multiplier?
iccaros
thanks, I was going off your Valvecaster amp as a example and R.G.'s stuff, but the datasheet showed a ground for voltage multiplier..  wanted to make sure a connection to ground of the chip was assumed..
now back to work..  ;D
