NPN transistor tester circuit ?
Started by fuzzy645, January 02, 2012, 03:27:19 PM
fuzzy645
Besides reversing the battery orientation, would anything need to change in RG's transistor tester circuit below to test NPN transistors instead of PNP?
Thank you
jrod
Nope, just the battery.
Edit: Oh and the test leads. Make sure your test leads are connected correctly. Black to ground and red to 9v+.
sgmezei
Would you adjust anything in the circuit if you are using a wallwart adapter?
My 1Spot puts out 9.4v steady, would I want to adjust the resistors or anything?
jrod
Nope, You shouldn't need to adjust any of the existing resistors in the circuit with a wall adapter. The .4v over 9v shouldn't make any noticeable difference. What will matter more is the temp of the room.
artifus
#4
Quote from: sgmezei on February 15, 2012, 01:05:07 PMMy 1Spot puts out 9.4v steady, would I want to adjust the resistors or anything?
check a fresh battery. or two. don't always believe what it says on the label... (this doesn't just apply to batteries...)
