MXR Micro Amp, from General Guitar Gadgets.
Started by markbee, January 07, 2012, 07:52:49 AM
arma61
Have you tried to figure out how the signal flows through the switch ? I'd do that before soldering it.
something like this
Ciao
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
markbee
#41
everthing looks okay in Position 1 - the wire from number 5 goes through the board and then through the wire to the input jack so it shall be grounded? everything seems to be wired well although it still lookes like a grounding problem.
markbee
#42
ITS ALIVE! :D its finally working! :)) but the led doesnt shine and the boosting seems to be stuffed in the last quarter of the potentiometer turning, well it boosts from the middle but its very slight and then really sudden volume gain ... any idea how to fix that?
arma61
Quote from: markbee on January 12, 2012, 12:59:25 PM
hey man, you did it!!! well done!!
Stupid answers
have you tested it's working with a battery + resistor (4.7k to be on the safe side) ?
have you checked polarity of the LED ?
is the pot the right one, so a 500k Reverse Log ?
may be now that you got it working you could post voltages as per that thread I've pointed some time ago.
Again, well done m8, what was the problem at the end ???
Ciao
markbee
I must have forgotten to check the LED, i probably wired it the wrong way :)
I have used the exact same potentiometer as was written in the bill of materials,
I tried to measure the voltages and almost all of it seems wrong to me, i probably dont know how to measure it properly :-|
IC1
P1 43 mV
P2 4,4 V
P3 2,3 V
P4 keeps giving me 0 for some reason
P5 265 mV
P6 8,86 V
P7 4,41 V
P8 43 mV
Well the problem was in grounding, i noticed that the one part of the output jack is touching the enclosure so i put a little tape underneath it and it started to work :D
arma61
Hi (sorry if all this sound a little bit boring... )
first of all use a fresh new batter to check your DMM is working good....
now let's talk about the same pins
looking at the IC name/mark/stamp, make sure you have the notch on the top and/or a dot on the top/left corner
the pin on the left of the notch is pin 1, the one on the right is 8, so measure the pins like this
1 8
2 7
3 6
4 5
you should have readings almost like these
1 - 0
2 - 4.2v
3 - 2.4v
4 - 0
5 - 0
6 - 4.4v
7 - 8.8v
8 - 0v
Ciao
twabelljr
Shine On !!!
markbee
thanks, i measured it once again and it is correct :) what shall be causing that gain coming in the second half of pot rotation? wrong pot is the first thing that occured to me but i ordered the exact one from US to have everything right :))
