Utilizing George Giblet's parametric EQ ...? Schematics included
Started by gregwbush, January 09, 2012, 04:07:17 AM
gregwbush
This layout should work
... but i haven't built it yet
I will though, it's the perfect little box to switch from my normal mid rangy rock tone to a more modern metal sound (mid cut) without needing separate distortion pedals
Edit: As in, if you're not already aware; EQ can be (or in my opinion, is) waaaaaaaaay more influential than the amount of distortion
nochtanseenspecht
thanks for the schematic!
i've made this eq also, as part of a spring reverb driver circuit,
it works fine but i was wondering if there is a way to get more resonance out of it,
it sweeps a bit to weak for my taste..
other than that it is a nice simple and usefull eq
