Have any of you measured NKT275s from AM Sunface?
Started by sockeye, January 19, 2012, 03:47:32 PM
sockeye
Hi all,
I have to say, this is an awfully good sounding FF. I had one that I sold and am wishing I had taken some measurements before I sold it.
My question is: has anyone on here taken measurements of Q1 and Q2 from an AM Sunface? Best of all would be if you have gain and leakage measurements from an Atlas DCA. I have a lot of Ge PNPs in appropriate gain ranges, but before I audition them all on the breadboard, I'd like to pull some that measure close to the NKT275s that Mike uses.
thanks in advance,
John
azrael
Don't spend too much time looking magic numbers.
IMO, if you get around the right gain range (60-80 for Q1, and 90-110 for Q2) and bias it right, you're 90% there. There are a lot of other things you can do to the circuit to get more drastic tonal improvements/changes to your tastes than searching around for magic transistors.
  They do what they do...
    Leakage is the big #1 for the transistors, Q1 low-ish gain and lower gain than Q2.
  Part #'s have little to say about how good the parts are for GE FF's etc., the leakage/gain number tell most of the complete story...the rest of the story is hardly worth telling unless you happen to have magic part#'s in transistors with 'actual magic' in them.
   I don't really believe in magic any more. I researched it to where I'm satisfied with the transistors I got, have, use, or can get...just saw 8 fresh-pull Ge's [from my 8 transistor radio !] surface once again, but I've got Ge/Ge/, Ge/Si, Si/Si and another Ge FF here already. Every one of them sounds a little different and I only take mental notes on 'em...bias 'em voice 'em, do maybe something else [fan of the starved/ducktone w/low voltage or nearly dead battery].
   If it's biasing and amplifying [a lot] it 'works'...the rest is up in the air...ten million mods etc.
   No two sound exactly the same and if they did I'd modify one...
