Have I made a Bandpass filter with this dual R-C filter?
Started by kimelopidaer, February 01, 2012, 03:36:35 PM
kimelopidaer
The following picture i based on a diagram of the muff tone stack over at AMZ effects.
Regarding band pass filters - For example let's say i wanted to pass only frequencies from 80 - 200 hz.
I chose component values for the high (>80hz) and low (<200hz) pass filters that combine to create this filter.
I used AMZ's R-C filter calc.
I would appreciate any comments regarding this method; I've also seen the high and low pass filters connected in series.
What if I just want a static value from the filter and I omit the voltage divider at the output?
ThankYou,
K
_dB
I believe the POT allows you to blend between the low passed and the high passed signals.  I guess at the mid point you'd get more or less a bandpass filter?
For static values the series configuration this is probably what you want: http://www.electronics-tutorials.ws/filter/filter_4.html  (fewer parts)
ubersam
download the duncan tone stack calculator and plug your values in to see how the filter behaves http://www.duncanamps.com/tsc/
check this page out for some examples of passive rc bandpass circuits: http://www.electronics-tutorials.ws/filter/filter_4.html
R1 C1 passes DC to 199Hz.
R2 C2 passes 80Hz to infinity.
So it passes everything.
In general, a parallel-path network like this can ony be all-pass or notch.
For simple bandpass, put the networks one after the other. First cut off bass, say at 400Hz. Then cut-off treble, say at 2KHz. Result is 400Hz-2KHz bandpass. Not a *sharp* band-pass such as fancy filter textbooks get into, but musically useful anyway.
merlinb
Quote from: kimelopidaer on February 01, 2012, 03:36:35 PM
Yes you make it bandpass, but it is pretty pathetic bandpass. You would do it the opposite way to the way you describe- HP filter set at 80Hz, LP filter set at 200Hz. Try out Duncan's TSC:
earthtonesaudio
No, a LPF and HPF in parallel (as in the drawing) makes a notch filter.
A LPF and HPF in series makes a bandpass filter.
merlinb
CynicalMan
I'd call that a peak filter, not a bandpass. Bandpasses usually reduce frequencies beyond the pass band towards 0. That one just increases the centre frequency towards 1 while the other frequencies are attenuated by a set amount. Still, I'm not sure that wouldn't fall into the strict definition of bandpass.
kimelopidaer
I see it now, thank you everyone for the replies -
The arrangement as I had it will attenuate frequencies above 200hz with the Low pass,
but then the High pass arrangement will allow all those frequencies to pass through anyway -
Putting the filters in series will let me do what I want.
Cheers for the learning,
K
earthtonesaudio
Thank you for the correction Merlin.  I did not look close enough at the values.
The parallel arrangement is what's used in the Big Muff and its many derivatives, where the values are often chosen to produce a notch response.  Upon closer look the parallel arrangement can be tweaked to produce a notch, or a mostly-flat response, or a mid bump.
