Buffer with specific output impedance
Started by ugly_guitar_guy, February 06, 2012, 01:29:28 PM
ugly_guitar_guy
Hey guys,
After building a new pedalboard to use with my Mesa Mark V I've run into an interesting issue that I didnt notice with my GT-10 I previously used.
Long story short, the FX send on the Mark V is 25k Ohms, and the return is 50k Ohms, so I need a buffer with a 50k Ohm output so that I can match the return (the DD-3 at the end of my fx chain is only 10k Ohm output and I can tell it's effecting the return tone).
Any direction to a buffer that can be dialed to that specific Ohm output?? Thanks!
Check out my metal band here: www.facebook.com/hollowshell
or
my personal effects building page here: www.facebook.com/brotronics
therecordingart
Quote from: ugly_guitar_guy on February 06, 2012, 01:29:28 PM
Hey guys,
You don't want to match the 50k ohm impedance on the return. In situations like this you want your source impedance to be 1/10th (or smaller) of the load impedance. By matching the impedance you'll see a 6db reduction in signal level vs a .8db reduction in signal level if the output impedance of your pedal were 5k.
ugly_guitar_guy
Quote from: therecordingart on February 06, 2012, 02:57:05 PM
Ok, so if the DD-3 is a 10k Ohm output then it should be close enough? I suppose there might be another reason for the loss of highs then, this just seemed like something obvious, but apparently I don't understand the concept well enough. Back to the drawing board. Thanks
or
DavenPaget
Quote from: ugly_guitar_guy on February 06, 2012, 03:14:39 PM
You would be safer with a TL072 buffer . 1K impedance . that's 1/50 ratio .
Hiatus
ugly_guitar_guy
Quote from: DavenPaget on February 06, 2012, 03:34:26 PM
Cool, I'll try something like this then and see how it works out.
or
