vero request
Started by petey twofinger, February 09, 2012, 03:46:38 PM
petey twofinger
ATM i only have vero to work with here , there is no schematic for this circuit , i am having a lil trouble figuring it alll out .
a vero would be a such a treat . i have a handfull of proper lmc567 now , after recieving the smt lmc567s that i waited 3 months from being out of stock at futurelec ...
http://aronnelson.com/gallery/main.php/v/ANY-machines/MayheM_/
http://www.diystompboxes.com/smfforum/index.php?action=printpage;topic=46995.0
any lm567 lmc567 vero layouts that i missed , i have a small collection here , really interested in a logan 5  , dr who , and the mayhem vero / scheme / mods etc . i realize there are a lot of theads about this chip , i have read thru a lot and have it all saved as well . just looking for veros , schemes , whatever may help . like i mentioned before i have a debilitating back injury , it becomes too painful for me  to work for too long ,  so  i may appear to be suiper-lazy but , i just want to maximize my time .
thanks or any info / effort / work in advance , petey .
im learning , we'll thats what i keep telling myself
digi2t
I have a Logan 5 vero available, but it's combined with another circuit.
The BOM is here; http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=45163 . Download the file, and change the name from "BOM_html" to "BOM.html". Then you'll be able to open it in IE.
If you draw a line directly under the +9v rail, everything above it gives you a Logan 5 vero. You can then shorten the vero by 4 holes as well. INPUT will be 3 holes up from the +9v, going into C10.
The circuit above is a dual circuit that I built a while back. It's a Digital Octave Fuzz (Escobedo's "Stupid CMOS tricks") combined with the Logan 5. I run the Logan after the DOF, with 2 stomp switches on the box. The DOF is pretty heavy, and if you throw in the Logan after it, it's mayhem. Here's a clip, first half if the DOF, then I throw on the Logan 5.
http://www.soundclick.com/player/single_player.cfm?songid=10490290&q=hi&newref=1
Cheers,
Dino
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
timd
Do you have the schem for The Thing Ring Mod? Very easy to build and crazy.
cab42
#3
Petey,
I'll be happy to give the MayheM a shot on vero. It may take a while though, I'm pretty busy at the moment.
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
petey twofinger
dino i had that layout and i was thinking the input would be at the pot a lil lower so thanks , going in at the cap actually makes sense ... i had also listened to your clip / read the dof thread . i very well may end up going with that design so thanks in advance .
i will also try that bom rename trick and see what i get .
timd i do have that layout , i am guessing i will start "simple" with this (the hemmo ver) , i do have four breadboards and i four chips . i figured i would try all them out and then see if i can come up with anything different on my own , but ... i like the idea of having a buffer or booster on the front , i really need to learn more about that . so far i discovered  the oorman jfett stuff , fetzer valves(?) , then op amp types . i would like to get a feel for 3 or four different types so i could know off the top of my head when and what is needed .
i think the main thing i will run into is the bleed thru , which appears to be a fact of life with this chip .
i have had a thing for R.M. since the first devo album , i do have a rack mount piaa R.M. here , it is a bit noisy , but i did use it .
http://soundclick.com/share.cfm?id=7894385
thanks so much , for everything and especially the vero for MaheM! , i really appreciate that / need to learn how to make those myself !
