Rat Feedback Loop EQ
Started by seedlings, February 15, 2012, 10:25:06 AM
seedlings
In the ProCo Rat, there are two filters in the feedback loop.  The 560R-4.7uF is tuned to 60Hz gain of 267, while the 47R-2.2uF is up at 1500Hz gain of 3191.
Does this mean there is partial boost from 60Hz to 1500Hz, and a full boost from 1500Hz up, or do they interact so that the knee is somewhere between 60 and 1500Hz?
CHAD
seedlings
From reading about that Ruez mod, I gather 60Hz to 1500Hz has 267 gain and 1500Hz up is 3191 gain.
CHAD
> 1500Hz gain of 3191
1500 times 3191 is 4.8MHz gain-bandwidth.
The LM308 doesn't have that much gain-bandwidth.
It must be dropping before 1.5KHz.
The dual-RC adds a little change in the lowest octave.
http://www.diystompboxes.com/smfforum/index.php?topic=92931.0
seedlings
#3
Quote from: PRR on February 16, 2012, 01:04:31 AM
So the highs keep getting "rolled back" as gain increases... a bandpass filter.
I'm using an LM833n with gain-bandwidth of 15MHz, so in theory this would limit frequency to 4700Hz.  Thank you for introducing me to a new term!
CHAD
WGTP
There is some low-mid/bass boost with the 2 "leg" setup.  Or, you could think of it as a low-mid dip.  ;)
Stomping Out Sparks & Flames
