Dr. Boogie/Amp sim Question
Started by WGTP, February 15, 2012, 02:30:25 PM
WGTP
The small caps, 220pF in Dr. Boogie, that are attached from the gate to the source for the JFet/Tubes are for negative feedback and reduction of the highs, I'm guessing???  Thanks.  :)
Stomping Out Sparks & Flames
Davelectro
HF reduction. Yes.
They should go to ground, really...but it seems that when you have large bypass caps you get the same effect.
> should go to ground
Source impedance is generally SO much less than drain impedance that "source is as good as ground within 10%".
WGTP
Thanks gentlemen, another spot for EQ tweaks.  ;)
Caferacernoc
Same idea as a "snubbing" cap in parallel with the plate resistor in a tube amp or tube amp sim. Reduces just enough highs to hopefully prevent oscillations in a high gain amp. But can also be used for tone shaping. I think the 220pf value comes from the Fetzer valve article. It was used to simulate miller capacitance to keep out RF signals and further emulate the tube triode sound.
