My Dual Caster Died
Started by blown240, February 16, 2012, 10:31:37 PM
blown240
I went to use my dual caster today, and it doesnt work.  Last time I used it, it was fine.
The circuit is a normal dual valve caster.
There are no obvious loose wires.
With the DPDT bypass switch off, the signal goes thru no problem.
I bypassed the switch and that didnt fix it.
It is for sure getting power since the tubes glow nicely
I tried different tubes.
I poked around with a dowel rod and no difference.
You CAN hear a difference in the static, when the tone knob or volume knob are turned. but not when the gain knobs
are turned.
I was playing thru my little gem, which works fine by itself.
Thoughts, ideas?
gregwbush
Tubes glowing means the heaters are on. Not necessarily the rest of the circuit
blown240
I agree.   I was just using the tubes glowing to show that the pedal is getting power.  I tried different tubes, but that didn't help.
Earthscum
Quote from: blown240 on February 17, 2012, 10:52:18 AM
Quote from: gregwbush on February 17, 2012, 08:22:47 AM
What he was getting at is that just because you are getting 12V at the heaters doesn't mean you are getting B+ voltage to the plates.
runmikeyrun
Quote from: petemoore on February 17, 2012, 07:09:11 AM
  Audio probe it.
This.  Start at the input jack and work your way through from start to finish until you find where your signal stops.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
