3D models of your builds - SolidWorks
Started by gtudoran, February 17, 2012, 08:54:49 AM
gtudoran
Hey guys,
For about 1 week i've played with SolidWorks for 3D models and assembly process. So here is my first 3d mode - a 6 loop switcher with an included power supply.
Best regards,
Gabriel Tudoran
Analog Sound
PS: if someone is intrested i can provide the 3d models made in SolidWorks.
PDF of the 3d model: http://dl.dropbox.com/u/15275178/Solidworks/Sw_Projects/Switcher/Assambly-looperV3.PDF
defaced
Very cool!  I model alot of my builds so I can iron out any mechanical interferences ahead of drilling/assembly.  I've done a couple of projects this way, but this is the only one I've got shots of at the moment.  http://www.buildyourownclone.com/board/viewtopic.php?f=8&t=33177
It looks pretty trivial, I mean they're just pots and switches on a front face, but the clearance between them is often less than 0.050", so having the ability to move them before I drill helped get it right the first time.
-Mike
a soBer Newt
gtudoran
diemilchmann
We should start a custom library for all these parts! I know i have some pretty detailed jacks models and whatnot somewhere...
Perrow
I used Sketchup when I planned my 1590A Superfly build.
There's Hammond enclosures in the online library, as well as switchcraft jacks (made by someone on this forum, the jack model that is).
Galego
Steve Mavronis
I did mine in 2D using GIMP layers. I should have tried 3D in Blender for these cool angles and cutaways!
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
proaudioguy
You DI really great work.  As an audio engineer in live sound I can tell you if I see an xlr direct output that does. It have a ground lift switch for pin 1 I do NOT use it. Manufacturers of music equipment seem to have no idea of how ground loops work. Google "the pin 1 problem" and also check out the synaudcon and papers by Bill Whitlock and Don Pearson in regards to grounding and the pin 1 problem. Basically electrical and audio grounds should be isolated from one another. Good luck.  Maybe you will be the first to put a pin 1 lift switch at the output of your amp!
easilyamused
Here's my generic stompbox - I did it for some testing of Creo Parametric, but the files are available in STEP format
https://grabcad.com/library/guitar-stompbox
gtudoran
A new 2 channel guitar preamp in SW:
Best regards,
Gabriel Tudoran
Analog Sound
