Little Angel Space Madness Mod
Started by garcho, February 26, 2012, 11:19:36 PM
Cool mod. What you're doing is turning the transistor on and off, so the delay time will swing between the short time set by the 100R resistor and the longer one set by the 2k. You could try sticking a pot in series with the 2k, that should get you different sounds by changing the length of the longer delay. You could also try disconnecting the 47u cap when you switch your mod in, that might make the modulation work over a greater range of depths and speeds. You still need the cap there at power up so the transistor circuit does its real job.
Thanks Slacker! I'm a total ignoramus and need guidance to understand even the basics. I haven't had time to look at this and will explore more in a week. Will definitely try your suggestions. Excited!
