True Bypass Wiring: How important is it to ground effect IN or Effect Out.
Started by goldstache, March 08, 2012, 01:51:17 PM
goldstache
Just wondering the pros and cons and philosophy in grounding the Input of FX, and Output of FX when wiring true bypass?
Is there "crosstalk" when not grounded?
I usually ground the input side.  I just was contemplating why you see this configuration in so many different builds.
rousejeremy
From my experience high gain pedals almost always need the input grounded. I built a fuzz factory one time that while in oscillation the squealing could still be heard when bypassed, input grounding solved that problem.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
Govmnt_Lacky
When I started building, I grounded the Input side. Now, I don't ground it.
I have not noticed a difference.
My $0.02
goldstache
Awesome Guys thanks!  I figured it was dependent on the circuit and tailoring to suit your needs!!!
I do it on all recent builds regadless as i'm using 3pdt stomp switches now so all that's involved is adding one jumper to the switch.
