is my MXR Microamp supposed to hiss?
Started by runmikeyrun, March 27, 2012, 12:31:44 AM
runmikeyrun
I've tried both the 741 and a TL071 and it hisses like crazy.  Is this some sort of inherent design flaw, or is something wrong?
Bassist for Foul Spirits
Head tinkerer at Torch Effects
Instagram: @torcheffects
Likes: old motorcycles, old music
Dislikes: old women
Everything hisses.
Full-down, the hiss should be comparable to straight into a guitar amp.
Full-up should be 10 times hissier.
The schematic I found shows a TL061, not a '071, and certainly not a 741.
You know where the DEBUG post is.
runmikeyrun
Quote from: PRR on March 27, 2012, 12:58:32 AM
Everything hisses.
I deserved that scolding, LOL!
Thanks Paul, I'll check it out.  Might order an 061 to see what happens.  The schem I went off was from GGG, it used a 741.
Dislikes: old women
The TL061 hisses a little more than the TL071, but saves on battery consumption.  If battery life is a non-issue, then the 71 is preferred.  If it hisses the same with both a 741 and a TL071, then something is wrong with your build.
I don't care '061 or '071; but the schematic I looked-up and found shows a 10Meg bias resistor which is way-high for a '741, and would have shown in debug voltages. As might other wiring errors.
