Question: Big Muff Pi Standard, could you add a Tone Wicker?
Started by Thisisyoureading, April 27, 2012, 02:32:21 PM
Thisisyoureading
I know you're probably saying 'Why not just buy a tone wicker?', well a) It means spending more money on something and b) I thought it might be cheaper to mod a toggle switch with the same function as the Tone Wicker onto the standard Big Muff Pi.
Is this at all possible?
nocentelli
Yes, but it might be a bit fiddly. From what I can gather, it is simply lifting the three B-C caps on Q1-3. You could remove them from the board and mount them on the switch, or lift one leg on each and run wires from the lifted legs + holes from whence they came to the switch.
DiscoVlad
GGG has the schematic showing how to do the tone bypass for transistor muffs too.
Electron Tornado
nocentelli is correct regarding the tone wicker mod. To lift all three caps you'll need either a 3PSP or 3PDP switch. The latter of the two might be easier to find.
The tone bypass will give you a volume boost, BUT will also give you a very noticeable increase in noise as well. Here's another option for modding the tone control:   http://guitarkitbuilder.com/content/big-muff-pi-mod-more-mid-range-tone
Using a switch, you can make the tone control selectable between stock, scooped mids, and flat mids. Download the tone stack calculator and you can tweak the tone control as you like. http://www.duncanamps.com/tsc/
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
DiscoVlad
The actual EH Tonewicker BMP uses a single pole toggle switch, and a 4066 (switch IC) to switch the 3 caps out - using something like this, or optocouplers would be more difficult, but less likely to cause popping from one lead of the capacitors being left floating.
Thisisyoureading
Thanks guys, I'll have a look at what you've all posted.
